LG 42PC1DG Plasma picture fault
  • dkneyle
    • Dec 2013
    • 441
    At start up there are a range of sparkle screens in a variety of colours which rotate through about every ½ second. You can see an image but it is as if it is out-of-sync. Jumps all over the place and fairly torn in appearance. Intensity seems low.
    I'm sure one of you plasma experts out there can direct me as to the the board which would have failed causing this sort of dodgy imagery.
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Re: LG 42PC1DG Plasma picture fault
    Control board or connection first choice.
    • Sevenqi
      • Jul 2011
      • 292
      Jumps all over the place --Do you mean the "No Signal" menu bar jumps ?
      adjust the VSRs on the y-sustain board to see if you can get rid of the sparkle (Mark the original position before adjustment)
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        Yes is this just at startup or ongoing and is menu accessible?. My info is low esr SMD caps on control board can be a problem and it is important for all voltages shown on panel tag to be basically within 1v being Vs Va Vsc Ve normally plus all connectors cleaned and reseated correctly. If menu available then reset to original specs.
        • dkneyle
          • Dec 2013
          • 441
          Thanks for all the pointers guys. I'll open it up and have a good look around. And "yes", the "No Signal" jumps all over the place, but is also quite torn in appearance; not a nice neat rectangle. I took some video and if I have no luck with the advice to date I'll post the video on YouTube. I haven't even pulled the back off yet; given what you say about sensitivity to voltages I wonder if it might be a power supply issue. Got a Sammy Plasma back into service in the weekend that had the old bulged capacitor problem. Some vintage set so maybe I'm looking at a similar issue.
          • dkneyle
            • Dec 2013
            • 441
            I've taken the back off and nothing jumps out as obviously wrong. Damned thing is built like a battleship. I've measured Vs and Va and they are spot on. I've posted a video here demonstrating the effect I'm getting: https://youtu.be/wib4Jfc5PiY
            Any immediate impressions of what the likely fault is much appreciated.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              X-Main ZSUS board failure in my opinion. The jagged, or 'torn' images you are describing are exactly what you'd expect with that failure on this model. Its an X3 based plasma. Check the fuse on the ZSUS board on the right looking at the TV from the back. It will almost certainly be blown.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                I watched the video you posted. I'd question a YSUS problem as well the way it's strobing but start with checking the fuse on the ZSUS first.
                • dkneyle
                  • Dec 2013
                  • 441
                  Fuses on X-Main Z-Sus all check out OK. There's two 4 amp cartridge types and two SMT types, all located on the bottom left hand corner of the ZSUS board.
                  I too was wondering if it was more a Y-Sus problem? Other than a board replacement not too sure what to go looking for or testing on the Y-Sus board?
                  • dkneyle
                    • Dec 2013
                    • 441
                    After having a PM conversation with TW2005 I decided to canabalise the TV. It has those dreaded IPM chips and I'm pretty sure it was a Y-Sus failure.
                    • brainbaby
                      LG Plasma TV with no picture fault finding
                      by brainbaby
                      Hi friends,
                      This is my first post in this forum and I hope I would fetch some of your valuable time
                      Let me brief, long story short..
                      I am working on an LG plasma TV model 42PQ30R.
                      The fault is no display.
                      The tv is turning on, the blue led is working, however there is no standby (red light), tv automatically going in run mode (i.e blue led)
                      Note: sometimes gets off automatically but it happened only once or twice.
                      I began my troubleshooting with the power supply, all fuse ok.
                      power supply ok, getting the required panel voltages...
                      09-07-2020, 11:24 PM
                    • KYBOSH
                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                      by KYBOSH
                      Saved this beast from the landfill this weekend.
                      Manfactured July 2013 in Mexico.
                      I love working on plasma TVs.
                      Its been a while but I was lucky enough to find 2 this week.
                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                      Will start troubleshooting tonight.
                      10-17-2024, 01:17 PM
                    • mmartell
                      RCA Virtuoso RHOS581SM-D Picture Fault
                      by mmartell
                      Picture looks stretched out and it looks like every other vertical line is not being drawn though hard to see that in the pics.
                      I've disconnected each half of the panel and the fault remains exact save for the disconnected side being white.
                      The original complaint was the tuner stopped working so the main was replaced however the new and old board exhibit the same picture defect.
                      Nothing is getting hot and pushing on the panel drivers effects no change in the picture.
                      So with that does anyone know how to enter the Service Menu on this...
                      02-05-2022, 10:53 AM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
