syncmaster p2770hd no power to touch panel
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    Hello. this device does not turn on for me. no lights on the front panel.
    My power supply voltages are all there.
    pwm>>0V
    13V>>13.25V
    grd
    grd
    grd
    grd
    5.2V>>5.25V
    5.2V>>>5.25V
    5.2V>>5.25V
    pwr_on>>0
    DCR>>0
    on/off>>0
    I'm not getting any power out of the connector leading to the touch panel/ ir sensor in the front.
    i guess I'm missing the "+3.3V_live" that leads to that.
    Does anyone have the schematics to this? I already checked toms service manuals.
    Also i believe i traced it to a bad voltage regulator but not sure.
    the part says 17-33 1127BG and in dpak form. i removed it and broke a leg. lol\
    The reason I thought it was this was because there was the 5.25V going into pin1 but was getting nothing out of pin 2 or 3.
    Is it save to assume this was the cause? I'm not the best at trouble shooting curcuits.
    can anyone help me find a replacement? couldn't find much details on this.
    thanks
    was going to replace with this one
    http://www.digikey.com/product-detai...7-1-ND/3505302
  • CapLeaker
    Leaking Member
    • 8146
    Re: syncmaster p2770hd no power to touch panel
    pwr_on>>0 (PSU)
    on/off>>0 (back lights)
    At this point the monitor is off and the back lights too. Upload some high quality pictures of your main board so we can see something.
      "17-33 1127BG' What DCV do you have on the 3 pins of the regulator with ref to GND?
      • dskall
        • Oct 2016
        • 2905
        • usa
        The 33 in part number may be the voltage of it and the 5.25v in sounds like you are on right track. Will need pictures to go further.
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          far right pin was the 5.25V
          I believe middle and left pins were nothing. Something less then 5 mV maybe. I cant remember and I already desoldered it. the right pin broke off easy when removing.
          • CapLeaker
            Leaking Member
            • 8146
            So either the voltage regulator was bad or something is shorted on the regulator output dragging it down?
            • sdinelli
              Sdinelli
              • Aug 2014
              • 152
              i noticed something that i wasn't sure if it was the design of the board or not.
              pad 1 and pad 2 of where the regulator sits(left and center) has zero resistance between them.
              does that sound fishy to you?
                If you look at the IC with the tab up, left pin is GND (for this fixed output), middle pin /big tab is output, right pin is input.
                So you may have shorted load, output filter caps, so remove the IC and check the resistance of the middle pin and GND again.
                You should also look up the spec sheet of this 3.3V REG.
                • sdinelli
                  Sdinelli
                  • Aug 2014
                  • 152
                  I Had trouble finding the spec sheet for this exact regulator. cant even tell what brand it is. it just looks like symbols lol
                  I checked the resistance of the middle pin to ground. it fluctuated not going higher then .4ohms( not kohms)
                  the regulator beside it middle tab had .455 kohms
                  I measured R118 right behind the regulator in question
                  labeled 1R0 - measured 1ohm
                  • sdinelli
                    Sdinelli
                    • Aug 2014
                    • 152
                    Well I ordered that 3.3V regulator in my first post so we shall see what happens.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      So you have short you will have to work out before replacing regulator
                      • CapLeaker
                        Leaking Member
                        • 8146
                        smells fishy, looks fishy, is fishy! Yes, you'd have to remove that short first.
                        • sdinelli
                          Sdinelli
                          • Aug 2014
                          • 152
                          I'm not sure exactly what to check because I don't the schematics but I guess ill try to poke around.
                            Remove the regulator then check the resistance between the middle pad and GND to see if it shows <1 Ohm or not as suggested in my post #8 which you did so it is not the IC that is shorted.
                            Can I see the closed up pictures where that regulator is? you may have to remove some caps next.
                            • sdinelli
                              Sdinelli
                              • Aug 2014
                              • 152
                              The picture of the removed regulator is posted above.
                              Heres a closeup of the board with out it.
                              and the back side right behind it
                              • sdinelli
                                Sdinelli
                                • Aug 2014
                                • 152
                                Does anyone think it could be the schottky diode on the back side?
                                it measured .067V and .04 V reversed.
                                I should probably remove it and retest huh?
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Diodes are best tested with at least one end lifted from the board.
                                  • sdinelli
                                    Sdinelli
                                    • Aug 2014
                                    • 152
                                    removed the schottky diode D103 from the back side
                                    It says 106 B340
                                    I measured .166V and OL reversed
                                    this is no Bueno correct?
                                    If it is indeed bad would this be a good replacement?
                                    http://www.digikey.com/product-detai...DICT-ND/768811
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      Those reading appear to be good.
                                      • sdinelli
                                        Sdinelli
                                        • Aug 2014
                                        • 152
                                        Ugh. I thought the voltage was supposed to be between .3 and .7 normally.
                                        • trepachka
                                          Converting HP EliteBook 840 G7 non-touch to touch if possible
                                          by trepachka
                                          I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                                          The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                                          I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                                          04-27-2024, 11:15 PM
                                        • Prott
                                          Surface Pro 4/5 - no touch after LCD change
                                          by Prott
                                          I have a question that's driving me a bit nuts recently.
                                          Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
                                          - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
                                          - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
                                          01-25-2023, 12:42 PM
                                        • howardc64
                                          LG 49UJ6500 LCD panel lighter band that goes away
                                          by howardc64
                                          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                          02-19-2023, 12:13 AM
                                        • triplefour
                                          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                          by triplefour
                                          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                          tcon is built into mainboard.
                                          Only one cable goes to panel boards.
                                          there is a cable from one panel board to the other that links them.
                                          cost cutting measure that results in us having harder time to diagnose.
                                          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                          07-28-2022, 07:59 PM
                                        • Storyteller12
                                          QN55Q60R Service Menu Panel Help
                                          by Storyteller12
                                          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                          01-13-2024, 01:57 PM
