Samsung UN40H6203AFXZA, no backlight or picture
  • joeblah
    • Apr 2016
    • 65
    Hello all,
    Would really appreciate anyone's input on this. UN40H6203AFXZA, no LEDs lit. I started by looking through the following thread:
    https://www.badcaps.net/forum/showthread.php?t=58767
    All measurements to main board from CNM803 look within tolerance. Bridge rectifier readings are good. It's the measurements from CNL802 that I'm concerned about. Power board P/N is BN44-00773C.
    I also looked at the LED strips and nothing looks charred (as it did in the aforementioned post). I tried to power a strip (strip P/N D3GE-400SMA-R2) without success (my Agilent DC power supply only goes to 60VDC, but that should have been enough to power one strip... I think). Other known good LED strips power up fine from the same DC supply.
    Back to CNL802; at D1+ I get 176VDC, all other pins at CNL802 are below 20mV. Resistance between D1+ and chassis is ~16MΩ.
    Trying to decide whether it's the power board or LEDs? Thanks for any suggestions!
    -Joe
    Re: Samsung UN40H6203AFXZA, no backlight or picture
    If you at the chart printed on the board, the LOADED LED Voltage is 151.8V since you are getting 176V it means there is open circuit in the LED string.
    http://www.shopjimmy.com/samsung-bn4...er-supply.htm#
    Pictures provided by shopjimmy.
    • CapLeaker
      Leaking Member
      • 8324
      agree on budm's comment above. x2
      • joeblah
        • Apr 2016
        • 65
        Awesome, thanks budm and CapLeaker!
          Make sure to use current limiter when testing the LED.
          • joeblah
            • Apr 2016
            • 65
            Thanks budm, will do.
              09-07-2024, 05:50 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Dodgethis
              Samsung QN75Q6DRA, No Picture, Has BL, and Sound
              by Dodgethis
              Hello all,
              This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
              09-11-2024, 07:39 AM
