No video-LG 42LG30
  • dprit
    • Jul 2015
    • 49
    No video-LG 42LG30
    LG 42LG30-UD After replacing Main board because of burnt regulator, I have back lights lit up and audio but no video/menu's/OSD. Remote and buttons on front will work. I've double checked to make sure the replacement main was same numbers as original. Any ideas?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: No video-LG 42LG30
    bad Tcon?
    • saddle_au
      Waste Warrior
      • 121
      Check all p/s caps. That model is notoriously bad here for that. Where did the burnt reg feed power to? Is TCON now dead? Check fuses on it.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Psu caps on the 42LG30 normally never ever fail they use a good series on these thats older models not the 3000 series. But I agree if Mb failed in that way Tcon is likely dead.
        • dprit
          • Jul 2015
          • 49
          I have ordered a TCON board and will post after it arrives.
          • dprit
            • Jul 2015
            • 49
            I replaced the TCON board but still have same problem. The IC that was burnt up on Main board is Q706. I will change the caps on the PS board and see.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Did you seat the LVDS cable from Main Bd to T-CON Bd properly? What about the ribbon cables from T-CON Bd to Panel? If all is good then you probably got a bad Main Bd and/or T-CON Bd bad.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                Rather check the LVDS with an oscilloscope first.
                • dprit
                  • Jul 2015
                  • 49
                  The problem was the Main board. The first one I order, although it had the right part number on the PC board, had a sticker that showed it was out of a 32inch set. The next one I ordered had a sticker that showed it was from/for a 42inch. After replacing with the 42inch board, video was perfect.
                  • rustytierod
                    • Sep 2014
                    • 81
                    I have this model (UA) and am experiencing quick white flashing when power on then blank with sound only. Something to do with back light or inverters because any cable disconnected from PS or to cfls and no flash.
                    Any known caps that cause this issue?
                    • electomech-fixer
                      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                      by electomech-fixer
                      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                      09-15-2025, 01:42 AM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • Asraf Atb
                      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                      by Asraf Atb
                      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                      01-27-2025, 05:02 PM
