Technika lcd42-207 humming, buzzing sound
  • london-freddie
    • May 2015
    • 472
    Hi all again
    Been given this tv to play with, its was going in skip
    TV all seems to work fine but has a humming sound coming from speakers, if sound is high it is not that noticeable but when the sound is low its there and it is annoying
    Took back cover off expecting to see some bulged leaky caps but everything looks fine, therefore with my limited knowledge I would not have any idea where to look next, any ideas please where to start looking, Power board is a 17PW16-2
    will post pics as soon as they upload from my camera to pc
  • london-freddie
    • May 2015
    • 472
    Re: Technika lcd42-207 humming, buzzing sound
    here are pics
    • diif
      • Feb 2014
      • 6978
      • England
      They might not be bulging or leaking but as it's a Vestel I'd suspect some of those caps are the culprit.
      I fixed a smaller Vestel recently with a hum from the speakers by replacing a few of the caps. Check the 3 green ones (IIRC 1000uf) with an ESR tester and the 2 at the top of the mainboard.
      • Techstar
        Tv Restoration
        • Dec 2012
        • 122
        • United Kingdom.
        Can't wait to hear from the experts on this one mate.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Test caps for esr on the mb, also the inverters Ive had cause a slight buzzing when the caps on it fail.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            First, is the hum on the speakers from all inputs tried.
            Can you hear it on the headphone out.
            Do you have access to an oscilloscope to look at the input /output of the audio IC
            • london-freddie
              • May 2015
              • 472
              hi thanks for the help
              humming seems to be on all inputs not tried headphone jack out
              have just changed the 3 X green 1000 16v caps on power board, humming is still there
              have not got the mainboard 1000 X 35v caps here to try them, will try and get some tomorrow
              • CapLeaker
                Leaking Member
                • 8218
                Look hard at capacitors next to a heat sink. Caps can look fine on the outside, but still be bad, specifically the little ones. You need an ESR meter.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  If my memory is correct I think someone had a similar problem on another thread in this forum where they cured the fault after resoldered all the pins on the audio chip.
                  • london-freddie
                    • May 2015
                    • 472
                    ok just done a naughty one, I have taken some 1000 35v caps off a scrap board and changed the 3 mainboard caps, just fired it up with no inputs connected yet and noise seems to have gone, it was noisy before with no inputs connected, will get it all back together and try it again
                    • london-freddie
                      • May 2015
                      • 472
                      ok all back together humming buzzing gone so looks like it was those mainboard caps, even though i have put on used caps, should probably replace them with new but think will leave these while its ok
                      • Techstar
                        Tv Restoration
                        • Dec 2012
                        • 122
                        • United Kingdom.
                        Nice one. One to remember that fault.
                        • ChaosLegionnaire
                          by ChaosLegionnaire
                          09-13-2022, 09:02 AM
                        • valente222
                          LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
                          by valente222
                          Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
                          11-18-2024, 03:21 PM
                        • Christos Tsiligiannis
                          Marian Trace Alpha sound card repair help
                          by Christos Tsiligiannis
                          Hello to the forum.
                          My name is Christos, I am new to the forum here and i am posting from Greece.
                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                          11-18-2024, 05:26 AM
                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:30 PM
                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
