Sony KDL-40NX711 Vertical Roll
  • SHADOW3277
    • Jun 2014
    • 123
    I picked this TV up over a year ago. At the time it had no power. I swapped out the power supply and it fixed the issue. I gave the TV to my parents and they've been using it ever since, until a week ago.
    The TV when turned on immediately has a vertical roll. I assumed a bad main board and ordered one from ShopJimmy along with a TCON in case I was wrong. They both came in and replacing both has not fixed the issue. I have cleaned the LVDS cables and the ribbons as well. I do have 12 volts across the TCON fuse.
    Can the panel going bad cause a vertical roll?
  • koka0011
    • Apr 2013
    • 30
    • Sri Lanka
    Re: Sony KDL-40NX711 Vertical Roll
    cut the lines on tcon ckv1/ckv2/ckvb1/ckvb2/stv
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I would remove the flat cables from the T-CON Bd to the panel one at a time and view the picture to see if it's the left or right side causing the double image and jump. Actually I couldn't determine those cables from the pictures. The side that shows the fault...that is the side to cut the lines as suggested by koka0011.
      • truep
        • Aug 2010
        • 373
        12V across the fuse? or do you mean 12V at both ends?
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          12V on both side of the fuse.
          • SHADOW3277
            • Jun 2014
            • 123
            12v on both sides of the fuse. I am at work right now. I'll try unhooking the ribbon cables one at a time when I get off.
            What will cutting those line on the ribbon do?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              NO...DO NOT CUT LINES ON THE RIBBON....the lines I refer to are on the Source/Driver Bd.
              • SHADOW3277
                • Jun 2014
                • 123
                Unhooking the right side ribbon cable (from the back view) clears up the picture on the other half. Unhooking the other side changes nothing. I am not following on the line cutting. I see the ckv1/ckv2/ckvb1 on the tcon. What and how am I supposed to cut? Sorry I am still learning all this.
                • SHADOW3277
                  • Jun 2014
                  • 123
                  Bump. Can you guys tell me what exactly I am supposed to cut and how?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    OK...So your problem is on the right side. Look at the right side cable lock/jack on the T-CON Bd and see if you can find CKV1/CKV2 and etc. Post a clear picture of both sides as the Left side may be labeled and the right side not labeled or vice-versa......No need to cut any thing. We may be able to use stationery tape to 'cut-off' the signal lines.
                    • SHADOW3277
                      • Jun 2014
                      • 123
                      I can see ckv1/ckv2/ckvb1 on the left side but not the right. Here are the pics.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        OK then.... on the right flat cable........ we do a trial and error now....taking a piece of stationery 3/4" tape cut along enough length to insulate that portion of the tip of the ribbon cable so as to prevent contact between them but continue to make contact with the rest...slip it in the slot and lock it....the Left side still connected....turn on the TV and see if there is a difference.....Keep moving the tape accordingly in different positions until you hit the 'sweet' spot.....and the picture is normal again.....I usually start from one end and continue to the other...It takes some time to remove and replace the tape and try it on...but you'll get there...GOOD LUCK.
                        • SHADOW3277
                          • Jun 2014
                          • 123
                          Andrew - After a lot of trial and error with the tape I've got clear picture (mostly). On the left side of the picture I can see some vertical lines and you can see where they end when you transition to the right ( the left side is darker than the right). Is this the best I can expect or should I keep trying to get it better. I've attached a pic, not sure how much it helps.
                          • jjanssen7
                            • Nov 2012
                            • 252
                            you should be able to get it pretty much perfect. I wonder if your tape is too wide. it only needs to be about 1/4 inch wide and placed all the way on the left or all the way on the right of the tconn ribbon.
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              Congratulations!!!!...You have done extremely well!!!...Yes it is very time consuming and yes the 3/4" tape could be too wide...look at where the edges of the tape rests....you may just have to go one or two gold fingers to the left or right...It takes a lot of work but when you reach that sweet spot...you'll feel really great.....
                              • SHADOW3277
                                • Jun 2014
                                • 123
                                Success! I cut the tape in half the picture is no longer darker on the one side.
                                Thank you everyone that weighed in to help!
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Can you post a screen picture of the completed repair for other to see the final results.
                                  • Daren87
                                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                    by Daren87
                                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                    08-13-2023, 03:25 PM
                                  • thelankanguy
                                    Sony KD-55X9000F TCON Issue
                                    by thelankanguy
                                    The TV shows a black screen with no image.
                                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                    Later both ribbons were disconnected and TCON voltages were tested.
                                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                    There is also a short to ground in this circled inductor.
                                    Is this a TCON issue or something else ?...
                                    12-13-2024, 12:27 AM
                                  • bbrain
                                    Sony KD-55AG9 TCON?
                                    by bbrain
                                    I have this problem with my Sony 55' AG9.
                                    It flashes 4x.
                                    I have found the service manual, and seems it is the TCON.
                                    Before I buy a TCON can someone check the vid?
                                    Thanks in advance!...
                                    09-19-2024, 10:50 AM
                                  • gpo23
                                    Sony KDL-40V3000 - Vertical lines
                                    by gpo23
                                    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                    With the new t-con the color are good but there are vertical lines on all the screen :
                                    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                    Is there a way to fix the vertical lines on the new t-con ?
                                    Thank you for your help
                                    gpo23...
                                    10-04-2023, 09:11 AM
                                  • motorahead
                                    Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                                    by motorahead
                                    Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                                    After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                                    10-21-2023, 03:50 PM
