Panasonic plasma tv won't come out of standby
  • Acerman
    • Oct 2016
    • 30
    • United Kingdom
    I have a 42 inch plasma tv (txp42c2b). It won't power on properly and is stuck on standby with a continuous red led blink . When switched on I can hear the relay click but it goes no further.I think that it is a single blink followed by a pause and then repeated over and over again.
    A bit of internet research leads me to think that 1 blink means dg board (main AV board). This is my first choice to test. Can anyone give me a good voltage test to test the main board.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic plasma tv won't come out of standby
    The 'click' you hear when plugging in the TV suggests that the Power Bd is OK. Count the number of flashes the red make. I think though that you may have a SC Bd problem. That is the board on the left, looking from the back. Post clear focused pics of the TV so we could see how the boards are interconnected so the more experienced than me could respond to you.
    • Acerman
      • Oct 2016
      • 30
      • United Kingdom
      Thanks for response.
      The previous owner told me that he changed the power board and that it made no difference. And some clicking noise from the relay is normal isn't it.
      The red standby led blinks continuously. it blinks once followed by a 3 second pause and the blinks again. That is repeated over and over again without stopping. I think this is a single blink in the panasonic diagnostics. A single blink on a panasonic plasma normally indicates the AV board. I want to test it but don't know which test to do. I am fully conversant with using a digital multimeter to test voltages on a TV with the rear panel as ground.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes 1 blink could mean an A Bd problem. Unplug, clean and reseat all the connector cables and see if that helps. And please, post clear focused pics of the TV so we could see how the boards are interconnected so the more experienced than me could respond to you.
        • Acerman
          • Oct 2016
          • 30
          • United Kingdom
          Here are the photos
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Id start by testing the SC board and SS as these sets the SC and SS have a habbit of blowing, if they are good then try mainboard.
            • Acerman
              • Oct 2016
              • 30
              • United Kingdom
              Thanks Reeceyburger. I will have a look at both .
              • cloo
                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                by cloo
                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                After doing a factory reset this problem was gone and the picture was back to...
                01-06-2025, 06:02 AM
              • rmacintosh
                Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                by rmacintosh
                I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                The symptoms of the tv ar as follows:
                • Plug AC in to back of TV
                • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                • The 3 blink code is given by the power LED
                • If the TV is unplugged and then
                03-14-2020, 12:24 AM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • orbit417
                Panasonic Plasma tc-p55vt50 6 blink error code
                by orbit417
                Hi All,
                Thank you in advance for your advice.
                I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
                I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
                I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
                04-14-2021, 09:11 AM
              • XCon
                LG 60PN6500 Plasma with standby, but won't power up.
                by XCon
                Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
                So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
                The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector...
                06-27-2025, 05:30 PM
