LG 47lw5700 back light no video
  • microvibe
    • Mar 2013
    • 275
    • canada
    I have LG 47lw5700
    Initial issue
    I get red standby press button turns blue backlight comes on but no video.
    I have 12v both sides tcon fuse.
    Pin out voltage
    NC 0v error
    12v 11.98v pwm
    12v 11.98v n. C.
    12v 11.98v drv on
    Gnd vsync
    Gnd gnd
    3.5v 3.48v
    3.5v 3.48v
    Gnd
    Gnd
    24v 24.1v
    Pwr on 3.48v
    If I unplug cable on left tcon to panel picture comes up on screen TV functions fine on that half. Is it a bad panel or tcon
    Re: LG 47lw5700 back light no video
    'If I unplug cable on left tcon to panel picture comes up on screen TV functions fine on that half'
    Bad panel.
    • microvibe
      • Mar 2013
      • 275
      • canada
      Damn thought maybe tcon or main guess nothing on the panel board could cause that . The board that connects to tcon from panel. When left disconnected it just stays white other side has picture. If I disconnect panel cable while TV on it gets some lines flicker.
      • microvibe
        • Mar 2013
        • 275
        • canada
        Found this corrosion on the board that's attached to the panel. Possible this could be causing problems? And panel still good.
        Cleaned it up but when I was probing psu to main pinouts I shorted 24v to ground now plug in relay clicks on psu I still have all voltages coming out of psu but no red standby does nothing when power button pressed. Would this panel be used in a LG 47lh30 or 47ld520?
          One of those LCD panel with tab bonding board on the bottom edge of the panel, people just spray the cleaner on the screen and it drips all the way down to the boards and ruin it.
          • microvibe
            • Mar 2013
            • 275
            • canada
            So not worth me trying to fix main board then. That corrosion ruined the panel
            • Brokit
              • Feb 2017
              • 7
              My 42LS570S displays half a good picture when I unplug the ribbon from the right side of the Tcon and a replacement Tcon did not fix the fault. The tab bonding board connected to the screen also shows sign of corrosion, probably due to liquid damage as above. The damaged board looks like it contains caps and resistors and the board its self and the bonded tabs look ok. I have found the LG specification sheet for the screen and board and replacements (left and right pair)are available if you do a search. I would like to attempt to replace the damaged components on the damaged rhs board but I am unable to find the circuit diagram stating the values of the components. The board is P/N 68705-13538 DESC - V12 42FHD Right Ver 1.0 H/F. Does anyone know/have any information on this board?
              • simo
                • 27
                i fixed one like this model, with the same problem, it was mainboard problem, i got a backlight but no picture, i did a CPU reflow,and i put a small fan to avoid any overheating in the futur, the Tv still working right now, it has been for 10 months ago, you can try with heatgun, just remove big balck heatsink and heat up a little bit the Bga chip,
                • microvibe
                  • Mar 2013
                  • 275
                  • canada
                  The video displays fine if one ribbon going to corroded tab bond board removed. Not main board. It has just bit corrosion I think I am going to clean it up starting probing caps comparing to other side . But right now I shorted 24v on main by mistake trying to fix that
                  • Brokit
                    • Feb 2017
                    • 7
                    42LS570S Does anyone have the circuit diagram stating the values of the resistors and capacitors on the board P/N 68705-13538 DESC - V12 42FHD Right Ver 1.0 H/F. Does anyone know/have any information on this board?
                    • microvibe
                      • Mar 2013
                      • 275
                      • canada
                      Would anyone know what other model uses this panel. I think I toasted this main board and there to pricey to buy for testing . I can get a little of 47-50" broken screen don't know what models tcons and main boards would Jimmy rig to test this panel.
                      • Brokit
                        • Feb 2017
                        • 7
                        I have the service manual for the 42LS570s but the title of the manual says it covers the 42LS570S,570T-ZB,42LS575S,575T-ZD as well. The main board number is EBT62013872 just in case your 47lw5700 uses the same board.
                        Have you tried a search for the 47lw5700 service manual. It may include other compatible models for your main board.
                        • Brokit
                          • Feb 2017
                          • 7
                          https://www.electronica-pt.com/esque...s-lb12c-26443/
                          • microvibe
                            • Mar 2013
                            • 275
                            • canada
                            Shows only 2 models but I know 55lw5700 same main board. How would you search where the panel itself is all used in
                            • Brokit
                              • Feb 2017
                              • 7
                              I would suggest doing a google search for the board number and see what results turn up. Sometimes websites selling spares list the compatible board models on their site.
                              • kca
                                by kca
                                Hello all ~
                                08-31-2025, 06:38 AM
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
                                Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                by sam_sam_sam
                                I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                I also have back when Light of America had these light bulbs available for yard lights
                                The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                While the Lithonia lighting fixture has all most certain bulb failure
                                So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                I have only had this light fixture for not more than a year if it...
                                07-02-2023, 03:45 PM
                                LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 03:40 AM
