LG 42LN5200 Vertical Line
+ More Options
Posts
  • DOPPLERBOB
    • Nov 2012
    • 12
    • usa
    Hi All,
    I am attempting to get the above mentioned set working. It has a July, 2013 date code and I purchased it on Black Friday, 2013. The original problem was a dark screen ( no backlight ) but everything else was normal. I determined it was the LED's at fault so I took it apart down to the LED's , tested each LED with my DVM on the diode test range so the LED"s would light up, and found one open LED. I tried reflowing the solder pads going to the LED just in case it was just a bad connection, but no luck. So I "bypassed" the LED using 5 1N4004 diodes in series. Bango, the LED's now light and the wife brings out the champagne. But I say not so fast. Lets wait until it is all together before we celebrate. So I reassembled everything back to just short of putting the back cover back on. I fire up the TV and darn, there is a 1/4 inch vertical line directly in the middle of the screen. The rest of the picture is perfect. I wonder if I damaged the LCD Panel? I tried re-seating the flex connectors going to the T-Con board, cleaned the contacts with meth, and even took the whole thing apart again to make sure the flexprints going to the panel didn't get crimped or something. Before I part the whole thing out I wanted to see if there was anything else I can to to verify for sure that the Vertical line is because of a damaged LCD. Any other things I can eliminate? Any ideas would be appreciated.
    Bob
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 42LN5200 Vertical Line
    Check the COF where the black line is? have you ripped it or lifted it by mistake.
    • DOPPLERBOB
      • Nov 2012
      • 12
      • usa
      I imagine COF is the flexprint that goes from the small PC boards directly to the LCD? If so, yes I checked them when I took the whole thing apart the second time. They looked OK, but I am wondering if there is a small tear that I cannot see internally. Maybe one of the traces inside the print? Is there any other troubleshooting I can do, such as what to expect if I lift the ribbons to the T-Con ect. and if they would eliminate anything else it could be. I have no way to fix and bond new prints going to the screen so if that is what it turns out to be then it will be lights out and put the champagne back on ice for the next celebration.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        I assume you disconnected the panel from the Tcon board when you worked on it by flicking up the connector tabs on the Tcon connectors to remove the ribbon cables.
        Reseat the ribbons again and ensure that they are correctly seated before closing down the flaps.
        • DOPPLERBOB
          • Nov 2012
          • 12
          • usa
          Yes sir, I did disconnect those ribbon cables when I took everything apart. I re-seated them several times hoping that it might correct the line. I also cleaned the connectors with meth ( I use methanol solution also on camera sensors because it doesn't leave residue behind).
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            If you apply careful pressure where the ribbon joins the panel or on the IC in the middle of the ribbon does the line go?
            • JeffJ
              • Apr 2012
              • 189
              The ribbons that go from the tcon to the panel, can you remove them and inspect the pad contacts. I have seen when seating them that a pad on the ribbons becomes sheared off, lifted and/or bent to the side and shorting another. I've done it my self.
              • DOPPLERBOB
                • Nov 2012
                • 12
                • usa
                Yes I tried that for quite sometime. All 6 of the ribbons that go to the panel and to the 2 thin PC boards along the bottom rail. I rubbed them all while watching the screen- the line never changed. I came to the conclusion that it is the LCD internally itself? Don't know if that could be it or not.
                • DOPPLERBOB
                  • Nov 2012
                  • 12
                  • usa
                  I will have to look at that closer and see. Thank You for that suggestion.
                  • DOPPLERBOB
                    • Nov 2012
                    • 12
                    • usa
                    All ribbons look fine. Both the ribbons and connector pins all look good under a mag glass. I swapped ribbons with same result. Guess the problem is the panel itself. Oh well I was so excited when I found the bad LED and bypassed it, and got the backlights to work. Guess I was too rough taking the panel apart to get to the backlights. Can't believe LG doesn't get a class action suit for this problem. This TV is barely 3 years old.
                    Off topic but does anybody have the correct approximate Backlight, Brightness, and Contrast settings I should set my NEW TV for to prevent this?
                    Bob
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
                    • almarhum
                      To fix laptop screen vertical line by working on its EDP cable
                      by almarhum
                      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                      05-07-2024, 02:12 PM
                    • mrsith
                      Samsung UE58TU7100K - no picture, vertical line
                      by mrsith
                      Hi.
                      Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                      This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                      Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                      02-07-2023, 11:18 AM
                    • bdalkiran
                      55EC930V white vertical line appeared (need help)
                      by bdalkiran
                      Dear All,
                      I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                      Please advice how to proceed and what is the...
                      01-13-2023, 04:16 PM
                    • tmhobadcap
                      VIZIO M60-C3 Can the vertical line be fixed?
                      by tmhobadcap
                      I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
                      02-05-2023, 03:37 AM
