Hi All,
I am attempting to get the above mentioned set working. It has a July, 2013 date code and I purchased it on Black Friday, 2013. The original problem was a dark screen ( no backlight ) but everything else was normal. I determined it was the LED's at fault so I took it apart down to the LED's , tested each LED with my DVM on the diode test range so the LED"s would light up, and found one open LED. I tried reflowing the solder pads going to the LED just in case it was just a bad connection, but no luck. So I "bypassed" the LED using 5 1N4004 diodes in series. Bango, the LED's now light and the wife brings out the champagne. But I say not so fast. Lets wait until it is all together before we celebrate. So I reassembled everything back to just short of putting the back cover back on. I fire up the TV and darn, there is a 1/4 inch vertical line directly in the middle of the screen. The rest of the picture is perfect. I wonder if I damaged the LCD Panel? I tried re-seating the flex connectors going to the T-Con board, cleaned the contacts with meth, and even took the whole thing apart again to make sure the flexprints going to the panel didn't get crimped or something. Before I part the whole thing out I wanted to see if there was anything else I can to to verify for sure that the Vertical line is because of a damaged LCD. Any other things I can eliminate? Any ideas would be appreciated.
Bob
Bob
