Eeprom dump thread!
This is a sticky topic.
  • porfyriadhs
    • Oct 2023
    • 70
    • Greece
    #1901
    VES315UNGB-L3-N53 screen model
    • cheeky2
      • Dec 2012
      • 337
      • uk
      #1902
      Looking for a working dump for the following Bush TV
      Model: BUSH LE-40GCL-A1
      Main: TP.SIS231.PT751
      Screen: V400HJ6-PE1​
      Attached is the faulty dump from the TV.
      Thanks for any help
      • lotas
        • Jan 2016
        • 4553
        • Russia
        #1903
        Thanks for any help
        Try this dump, but the panel is unknown.
        • cheeky2
          • Dec 2012
          • 337
          • uk
          #1904
          Thanks I will give it a go over the next few days and let you know the results
          • dinche_ze
            • Feb 2020
            • 16
            • Bosnia Hercegovina
            #1905
            hello friend
            I need spi flash for TESLA TV
            model: 43S306BF
            dont know matric number
            • lotas
              • Jan 2016
              • 4553
              • Russia
              #1906
              Originally posted by dinche_ze
              hello friend
              model: 43S306BF
              Don't you know the motherboard number either?
              • dinche_ze
                • Feb 2020
                • 16
                #1907
                • lotas
                  • Jan 2016
                  • 4553
                  • Russia
                  #1908
                  Post here your original, non-working dump, I'll try to fix it.​
                  • dinche_ze
                    • Feb 2020
                    • 16
                    #1909
                    problem is that remote control is not working, other things works fine.
                    • lotas
                      • Jan 2016
                      • 4553
                      • Russia
                      #1910
                      So what does the firmware have to do with it? If it doesn't work for you via the remote control, check the remote control, try via a universal remote control. If it doesn't work, replace the IR receiver, make sure the pulses reach the processor...
                      • dinche_ze
                        • Feb 2020
                        • 16
                        #1911
                        probao sam, ispravan daljinski, nece ni univerzalni. a ir prijemnik sa 4 pina,( 2 gnd, na jednom stalnih 5V, a na drugom 5V koji opada na 3,5V kada koristim daljinski), nemam takav ir da bi testirao ,mada sumnjam da je do njeg jer reaguje
                        • cheeky2
                          • Dec 2012
                          • 337
                          • uk
                          #1912
                          Thanks Lotas it worked a treat
                          • lotas
                            • Jan 2016
                            • 4553
                            • Russia
                            #1913
                            Ok!
                            • dinche_ze
                              • Feb 2020
                              • 16
                              #1914
                              Pozdrav prijatelji,
                              imam Toshiba 32el933g TV. Samo crveno svjetlo svijetli, ne pali se ni ništa. Kada sam ažurirao firmware, otkrio sam da se TV uključuje, ali nema slike. Mislim da se matrica ne podudara. Moja matrica je LG. Za drugu ne znam. Objavit ću originalni firmware od TV-a i novi ako netko zna kako ih uskladiti.
                              • lotas
                                • Jan 2016
                                • 4553
                                • Russia
                                #1915
                                Pozdrav prijatelji,
                                Try.
                                • dinche_ze
                                  • Feb 2020
                                  • 16
                                  #1916
                                  Try.
                                  it works.
                                  than you very much
                                  • lotas
                                    • Jan 2016
                                    • 4553
                                    • Russia
                                    #1917
                                    it works.
                                    than you very much
                                    That's good.
                                    • Salvatore Cancellieri
                                      • May 2025
                                      • 8
                                      • Italia
                                      #1918
                                      Hi everyone, I have a 65" Philips TV, it turns on and after a while it restarts endlessly, I checked the power supply and everything is ok, I disconnected all the devices and the panel but it continues to restart, I assume it is a dump problem, below is the original dump
                                      TV model 65PUS6523/12
                                      Board model 703TQHPL433 715G8709-M0B-B01-005K​
                                      • luzmina
                                        • May 2015
                                        • 17
                                        • US
                                        #1919
                                        Here is the dump for the Hisense 70H6570G and 70A6G. It fixed the corrupted EMMC issue that put the TV into a loop.
                                        Board RSAG7.820.9783/ROH
                                        https://drive.google.com/file/d/129h...usp=drive_link
                                        • digitel
                                          • Apr 2013
                                          • 8
                                          • Alicante
                                          #1920
                                          Please, do you have the firmware for a Hitachi 43HAE4251 TV, with Mainboard 17MB171 and Panel VES430UNDH-N2-N45? The memory is not SPI Flash. It's EMMc. Thank you.
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
