Eeprom dump thread!
This is a sticky topic.
    VES315UNGB-L3-N53 screen model
      Looking for a working dump for the following Bush TV
      Model: BUSH LE-40GCL-A1
      Main: TP.SIS231.PT751
      Screen: V400HJ6-PE1
      Attached is the faulty dump from the TV.
      Thanks for any help
        Screen: V400HJ6-PE1
        Thanks for any help
        Try this dump, but the panel is unknown.
          Thanks I will give it a go over the next few days and let you know the results
            hello friend
            I need spi flash for TESLA TV
            model: 43S306BF
            dont know matric number
              Originally posted by dinche_ze View Post
              hello friend
              model: 43S306BF
              Don't you know the motherboard number either?
                  Post here your original, non-working dump, I'll try to fix it.
                    problem is that remote control is not working, other things works fine.
                      So what does the firmware have to do with it? If it doesn't work for you via the remote control, check the remote control, try via a universal remote control. If it doesn't work, replace the IR receiver, make sure the pulses reach the processor...
                        probao sam, ispravan daljinski, nece ni univerzalni. a ir prijemnik sa 4 pina,( 2 gnd, na jednom stalnih 5V, a na drugom 5V koji opada na 3,5V kada koristim daljinski), nemam takav ir da bi testirao ,mada sumnjam da je do njeg jer reaguje
                          Thanks Lotas it worked a treat
                            Ok!
