Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4589
    • Russia
    #1541
    Re: Eeprom dump thread!
    Motherboard BN41-02156A ? BN94-xxxxx ?
    • Cf elettronica
      • May 2023
      • 10
      • Italy
      #1542
      The first one BN41-02156A
      • lotas
        • Jan 2016
        • 4589
        • Russia
        #1543
        It is from your model (ue48h6670sz) that I don't have, I have many other dumps from this chassis and it is from BN41-02156A. You need?
        • Cf elettronica
          • May 2023
          • 10
          • Italy
          #1544
          I could try with your version. Do you think it could work as well?
          • lotas
            • Jan 2016
            • 4589
            • Russia
            #1545
            Are you sure you have a problem in firmware 25Q40? You can try with my dump, just don't forget to keep your native dump!
            • Cf elettronica
              • May 2023
              • 10
              • Italy
              #1546
              I'm pretty sure it's a firmware issue. I only have ch341 programmer so i'm not able to flash the nand chip. I hope for the best or i will buy new tv. My readings into chip are most FF and some others unsignificant values. Any ideas for tv stuck on boot logo?
              • lotas
                • Jan 2016
                • 4589
                • Russia
                #1547
                In this chassis, flashing eeprom (24C256) often helps from freezing on the "Smart TV" log, if it does not help, then flashing the entire set (eMMC, Spi flash and Eeprom).
                • Cf elettronica
                  • May 2023
                  • 10
                  • Italy
                  #1548
                  Just in case, please do you have also the eeprom file? My eeprom is labeled IC901 part number s24c51. Thank you
                  • Cf elettronica
                    • May 2023
                    • 10
                    • Italy
                    #1549
                    Do anyone has it please?
                    • lotas
                      • Jan 2016
                      • 4589
                      • Russia
                      #1550
                      Who, exactly what?
                      • datriad
                        • Jan 2014
                        Does anyone have a dump For Vizio m60 d1 please
                        • sylves
                          • Apr 2016
                          • 10
                          • usa
                          #1552
                          I have a Samsung un55ku6290f that turns on as soon as I plug it up. There is backlight but that's it. No image or remote control functions at all. Could this be a bad bios.
                          • rott
                            • Jan 2015
                            • cyprus
                            #1553
                            Hi guys I'm looking for a firmware for a Samsung tv, model UE55J6200AWXXH
                            Board code BN41-02353B
                            Model : BN41-02353
                            Thank you
                            • sylves
                              • Apr 2016
                              • 10
                              • usa
                              #1554
                              Insignia NS-50L260A13
                              Here is a working spi flash for Insignia ns-50L260A13
                              • kyowee
                                • Aug 2014
                                #1555
                                I need flash dump for Sharp LC-60LE740E mainboard DKEYDF733FM65, QPWBXF733WJN2
                                • lotas
                                  • Jan 2016
                                  • 4589
                                  • Russia
                                  #1556
                                  Dump what eeprom, nand...? Post your non-working dump here.
                                  • kyowee
                                    • Aug 2014
                                    #1557
                                    The nand I need (IC8401), i thought mentioning flash would be enough.
                                    The non working one is not relevant, the guy from whom the set is, upgraded the TV from USB stick for a different main board (LC-60LE745U) so now the lvds isn't working.
                                    • lotas
                                      • Jan 2016
                                      • 4589
                                      • Russia
                                      #1558
                                      Link to dupm nand in private messages, try it.
                                      • kyowee
                                        • Aug 2014
                                        #1559
                                        Thank You lotas!
                                        • xurplusxhop
                                          • Jan 2012
                                          • 36
                                          #1560
                                          I need working bin for HAIER LE32F6500 TV (TP.VST59S.PB813).
                                          Attached is my dump bin file. thanks
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
