Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
If you have never encountered eMMC, then it is better to replace the motherboard.
You can find any BN41-02528A motherboard (they only have different firmware for different panels), you just need to rewrite or replace the 25Q80 (where the panel settings, T-con are located).Last edited by lotas; 09-30-2022, 03:04 PM.Comment
I found a motherboard of the same reference extracted from a UE55KU6400 TV whose panel was broken but simply by programming the 25Q80 flash with the contents of that of my TV then the TV enters a looping start cycleIf you have never encountered eMMC, then it is better to replace the motherboard.
I can try to change the eMMC but the problem will be to find the program. Is the program easy to find and what hardware is needed to program it ? Is it possible to change it and then reprogram it directly on the motherboard ?Comment
I finally changed the motherboard and my TV is working again.I found a motherboard of the same reference extracted from a UE55KU6400 TV whose panel was broken but simply by programming the 25Q80 flash with the contents of that of my TV then the TV enters a looping start cycle
Attached are the dumps of the new motherboardAttached Filesif you find these attachements useful please consider making a small donation to the site
Good Day All,
Looking for dump for Samsung UN49M5300AFXZA Ver.FA01. Board number BN94-12049D.
Assistance in getting this as I believe the original is somehow corrupted.
Original dump attached incase it can be fixed.
Thanks...Attached Filesif you find these attachements useful please consider making a small donation to the site
Anything guys?
Issue is that standby LED will flash 5 times. Power supply is good. I've tried another bios dumped from a similar board and the standby light stopped flashing, TV will turn on for few seconds and then turn off. So this is why I believe bios is corrupted. Any Help??Last edited by shawnpsx323; 10-15-2022, 11:19 AM.Comment
tp.msd309.bp85 flas dumpI have a Blaupunkt 39/210I-GB-5B-F3HBKU-EU that has a corrupted flash ic as it is stuck in standby.
Main board TP.MSD309.BP85
screen V390HK1-LS6-Rev.C8
Does anyone have a working dump for this model or similar?
The only one I could find was on the russsian site here (which I cannot register on!)
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
I've spent the last few days scouring the web for a new EEPROM for my Vizio E550i-B2 with no success. Does anyone have a dump for this model?Comment
HelloThank you very much lotas.
In fact I can't fully test the binaries because I don't have the TV at home, I only have the electronic boards and the LED bars.
The second binary (ue55mu6105_ic1604_II.bin) doesn't work, I don't even have the standby led.
On the other hand, the first binary (ue55mu6105_ic1604.bin) seems to work: I have the standby LED, the tv turns on with the remote control and the backlighting turns on fine. On the other hand, to test the image, I will have to wait to return to my parents and it will only be in several weeks.
I will post back to the forum at that time.
Two months later I was able to return to my parents home and test the programming of the motherboard.
The TV restarted without any problem and the picture is perfect.
Thank you lotas
here is the corrupted philips bin file
65pus6162/05
sorry i cant seem to upload .bin file
can somebody advise pleaseAttached Filesif you find these attachements useful please consider making a small donation to the site
hope this is correctAttached Filesif you find these attachements useful please consider making a small donation to the site
And why is this size small, what chip did you read the dump from?Attached Filesif you find these attachements useful please consider making a small donation to the site
second attempt
re read this time selecting:
24 eeprom
AMTEL
AT24C128
from menu on left
sorry im new to thisAttached Filesif you find these attachements useful please consider making a small donation to the site
Try it, there are two dumps from different models, but the main is the same for everyone.Attached Filesif you find these attachements useful please consider making a small donation to the site
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
