Sharp LC-70LE857U - Wont power on
  • geodim_98
    • Jan 2017
    • 11
    Greetings folks! I have the Sharp Aquos 70" TV which I got from a friend of mine. When he had it, it was giving him the 2 slow flash, and then 5 fast flash error. When I got it to my house, it was giving me the one slow and one fast flash sequence. I have been reading this forum for the last 8 hours skimming for any help that would allow me to troubleshoot. I am REAL new to this, so the learning curve is gigantic. The back panel is off, and I have already tried the lamp error reset, and for a very long time, no matter what I tried, it was as if the buttons I was pushing weren't registering. I tried disconnecting the 4 ZIF socket cables from the TCON board, and reseated all the cables I could find in the TV but left the 4 cables on the TCON disconnected, and then did the VOL- and Input buttons and the backlight lit up, the first time I did it. The next time I did the same thing (this time with the ZIF cables reconnected on the TCON board, the flash code went back to a 2/5 sequence and the screen stayed dark. When I turn it off and back on again its back to the 1/1 sequence. The guy I got it from, changed out the mainboard, and the power board, and I still have the old ones. Doesn't look like the panel is broken, as I couldn't see any cracks when the back light actually came on. Component level repair isn't something I am great at, but I don't mind trying. Anyone has any suggestions or questions.. shoot them my way, hopefully I can fix this thing Thanks in advance!!
  • geodim_98
    • Jan 2017
    • 11
    Re: Sharp LC-70LE857U - Wont power on
    Reading some more posts.. Think I found another step in troubleshooting.. Couldn't figure out what everyone was talking about disconnecting corner cables.. till I just found pictures.. Cool.. will try that next....
    • geodim_98
      • Jan 2017
      • 11
      ok, so I missed one of the 4 flat ZIF cables on the TCON board, so I made sure that was seated and making a good connection... then I disconnected both of the corner cables. I still get the One long blink, and one short blink. So I did the Volume - & Input while plugging it in. Took a few seconds.. but the entire backlight lit up. Saw some vertical red stripes at first, but then it looked like a complete all lit backlight.. all nice and bright. The problem is, when I turn it off, and hit the power.. for a moment, I see a few vertical red stripes and then it just goes dark. Is this the point that I need to pull those tab boards.. off of the sides? Reset lamp driver errors? and I only see 4 drivers. I have been reading about 5? is it 5 tabs per driver? I haven't taken the drivers out yet.. just preparing myself for what I should see.
      Thanks!!
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        im sure budwich etc will see this thread soon and answer any questions you have ive not worked on this model/fault myself the main thing is you need to work out which side is faulty as once you have removed it there no going back if you chose the wrong side etc.
        are these the threads you have been looking at as theres a few now
        https://www.badcaps.net/forum/showth...rp+side+driver
        • mmartell
          • Oct 2013
          • 3189
          You have VERTICAL red lines or HORIZONTAL red lines ? Important distinction...
          And you're supposed to disconnect one corner ribbon at a time.
          • geodim_98
            • Jan 2017
            • 11
            Ok, so the lines that I saw were vertical. a small section of multi colors.. and then that went away.. and then the next time I started it up.. I saw some red vertical lines.. and then after a moment or two, those went away too.
            • budwich
              • Jul 2015
              • 3097
              the lines are probably not relevant... what is important is exactly what you have connected / disconnected at the time of the "test". As suggested, ensure that the tcon has all cables connected properly, disconnect one of the corner cables (between the bottom and side boards), turn on the set, what happens. Do the same test with the other corner cable, what it is the result?
              • geodim_98
                • Jan 2017
                • 11
                Ok, so here goes. I have all the TCON cables connected, and disconnected the left (facing the back of the TV) corner cable, and nothing, then I reconnected it, and disconnected the right corner cable, and I get the sharp logo, and I see the K when I put it into service mode. Problem is, when I take it out of maintenance mode, it wont boot. I get the 1/1 blink sequence telling me there is a lamp error. So from what I read, it seems that the right driver will need to be peeled off. Is this what is keeping it from booting up normally without having to put it into service mode? When I try to boot it up normally, its instantly right to the 1/1 flash sequence.
                Thanks!
                • mmartell
                  • Oct 2013
                  • 3189
                  Did you reset the Lamp Error when you we're in service mode ?
                  • geodim_98
                    • Jan 2017
                    • 11
                    How do I do this without having the remote? I didn't see that anywhere yet? Maybe I overlooked it.
                    Thanks again!
                    • mmartell
                      • Oct 2013
                      • 3189
                      Page 2 I think. You'll have to use the buttons on the tv and be careful not to change anything else in there or you could render the board inop.
                      • geodim_98
                        • Jan 2017
                        • 11
                        So I did a factory init. And the TV boots now, but the color is REALLY wacked out. TONS of red, and 3 small horizontal stripes across the bottom of the screen. I took a picture, I just have see if this post of the pic works...
                        http://www.picpaste.com/sharp70-2TauGHFI.JPG
                        Also getting crazy "trails" on the left side of the screen.
                        • geodim_98
                          • Jan 2017
                          • 11
                          I should also mention that at current state, the left side drivers are disconnected, but I have not peeled the bonds from the screen. I am getting from reading that the darkness may be from the tabs not being peeled, but how about the trails I am seeing? Is that also from the tabs not being peeled off of the LCD? That will have to be my next step.
                          • geodim_98
                            • Jan 2017
                            • 11
                            Anyone have any suggestions about this color issue? Seems to fade from red on the left to green on the right. Is this still because I haven't peeled the bonded tabs? or could this be a TCON issue too?
                            Thanks!
                            • budwich
                              • Jul 2015
                              • 3097
                              what are you waiting for????
                              • geodim_98
                                • Jan 2017
                                • 11
                                I was asking if the coloration issue was related to the Tab driver issue. I will peel the tabs when I have a few moments to take the front bezel off. So I was trying to get an opinion. Seeing as how I don't do this work every day, I like to try to be ultra cautious. That's what I was waiting for.
                                • Superbee_dad
                                  Sharp 80” long short flash backlight error - Help
                                  by Superbee_dad
                                  Hello Sharp TV experts
                                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                  01-24-2025, 11:51 PM
                                • ekozeko333
                                  by ekozeko333
                                  🧠 What I’ve Done So Far
                                  Flashed...
                                  06-21-2025, 02:48 AM
                                • corrize
                                  Nikon D800 camera - flash don’t work and capacitor don’t charge
                                  by corrize
                                  Hello, I'm stuck in troubleshooting…
                                  The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                  In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                  When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                  10-01-2022, 10:02 AM
                                • yucel-yucel
                                  Sharp LC-39LE652V Nand Flash
                                  by yucel-yucel
                                  Sharp LC-39LE652V model device could not be opened due to nand software error, we rewrote the nand software and it worked. But we were able to find the software without satellite, it does not see the internal satellite. Does this model have a working satellite version and software? Thanks in advance.
                                  Model ; Sharp LC-39LE652V
                                  Panel ; V390HK1-LE6
                                  Mainboard ; QPWBXG135WJZZ
                                  04-06-2023, 04:57 AM
                                • abajor
                                  Canon VIXIA HF S10 A read data from inernal flash memory.
                                  by abajor
                                  Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                  Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                  The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                  I think my best shot is to figure out a way to read the internal flash memory outside...
                                  07-20-2024, 12:04 AM
