LG - 49UB850V-ZD - No Video/Audio. Standby LED 3 Blinks. At My Wit's End!
  • Hermes07
    • Dec 2016
    • 9
    • United Kingdom
    Evening All,
    Having some trouble with an LG TV that failed a couple of months outside the warranty period.
    Link to the model here:- http://www.lg.com/uk/tvs/lg-49UB850V
    Before I start, I should say that although I've fixed a few simple things in the past, I know nothing about TVs other than what I've picked up trying to troubleshoot this and I'm not the sharpest when it comes to electronics or circuit diagrams so please bear with me if something simple goes way over my head
    I have looked through as many threads, Youtube videos and repair guides as I can find but can't see any that seem to be the exact same issue. This thing is driving me up the wall so would really appreciate any input at all.
    The Problem:-
    Tried to turn the set on as normal one day and found it essentially dead. No Video. No Audio. No Backlight. No steady LED standby light on front of TV.
    On pressing the standby button on the remote (or the joystick on the back of the TV), the standby LED blinks on-off 3-times and then stays off permanently until you disconnect & reconnect the power from the mains.
    On the power board, there is a debug LED (LD701) which blinks amber on-off 5 times, repeatedly. This happens around 30 seconds after an attempt to turn the set on using the standby button.
    What I've Tried:-
    Firstly, I managed to find an LG service manual for a similar model that looks close enough for the instructions to be relevant. PDF attached.
    Tried turning the set off from the mains for 12 hours and back on as sometimes suggested by LG support. No difference.
    Checked the power board visually for any bad capacitors/resistors but can't see anything that looks bulged/burnt/damaged. I realise something could still have failed without any obvious signs but my soldering isn't great and I didn't think taking the big caps off the board to test them outside the circuit was a good idea before I'd checked the voltages.
    Checked all the voltages on the 28-pin connector that joins the main board to the logic board as suggested by the service manual. Readings:-
    3.5v = 3.54v (Standby & Power On)
    12v = 11.79v (Power On)
    24v = 23.7v (Power On)
    SLCK, SW & YSYNC = All 1v (Power On)
    Also spotted a row of test points for what I'm guessing are the LED circuits at the top of the PSU board so tested them as well in case anything jumped out.
    P210 = 48.8v
    EL85 = 0.8v
    EL86 = 0.82v
    EL87 = 0.8v
    EL82 = 0.82v
    EL83 = 0.8v
    EL84 = 0.82v
    EL79 = 0.76v
    EL80 = 0.81v
    EL81 = 0.85v
    EL78 = 0.78v
    EL77 = 0.78v
    EL76 = 0.8v
    Not quite sure what values these should be at so these readings didn't really tell me much.
    I tried the flashlight test to see if I could pick up any image at all on the screen. Saw nothing - completely black.
    Tried the hairdryer trick (Don't have a heat gun sadly) on the BGA mounted components on the Logic board (took off the heatsinks first) as a lot of people reported this had solved similar problems. No Difference.
    Next Steps:-
    I was pretty confused at this point as the LG manual seems to indicate you should replace the Logic board if you have no power but the main connector voltages all test OK. On the other hand, threads & videos (especially ones related to the flashlight test) were suggesting it would be a failed backlight in this situation.
    As I thought I'd probably destroy the TV for good if I took the screen apart to start following guides on how to test the LEDs, I said I may as well change the Logic board as LG suggest, and the engineer at the parts supply website I ordered from in the UK also thought that was the most likely fault.
    I swapped the new logic board in today and the issue is still there. The only difference it has made is that the steady red standby LED now comes on as soon as the mains power is connected. It still blinks 3 times and then stays off when you try to take the TV off standby.
    I've attached photos of the set as it currently stands with the new logic board. They seem to have got compressed a lot in uploading but I think you can still make out the details - if not, let me know and I will try to find a better way to upload.
    I'll be very grateful for suggestions on what to try next. I was hoping the new logic board would be the answer but it didn't cost much so I'm not too cut up about the fact it didn't work. The TV will only go in the bin if I don't fix it so I'm happy to start disassembling the screen and de-soldering at this stage although if swapping a board would fix it I'd rather do that and play it safe.
    Thanks in advance.
  • Hermes07
    • Dec 2016
    • 9
    • United Kingdom
    Re: LG - 49UB850V-ZD - No Video/Audio. Standby LED 3 Blinks. At My Wit's End!
    Sorry to pester but anyone have any thoughts/ideas at all on this?
    Not going to be economical to send for repair so it will only go in the bin.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      What does the black and white connectors on the Psu do when the set tries to power up ? Seems to me like the Led driver isnt running. Also what voltage have you got across the main caps ?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        With the back off do the leds flash briefly when you power up?
        Can you give the DC voltages on P801 & P802 when you power up. They may initially be high and then drop quickly so if you have a max min on your meter would prove useful
        • besetbyall
          • Jul 2018
          • 4
          Revival of an old thread, but was there any resolution to your issue? I'm having the same issue with an LG 50UF8300 set. Went through a bunch of the same checks as you (connections, capacitors, etc). Through i narrowed it down to the t-conn or logic board as the voltages seemed to check out on the legend listed on the power board.
          Initially, the TV powered on, LEDs would illuminate, but no picture. Sound was there. Replaced the tconn board, same symptoms. Power on, LEDs illuminate, sound OK, but still no picture.
          Recently replaced the logic board, and now the TV tries to power on, red standby light at the joystick will flash 3 times. And now similar to your initial symptoms, the debug light (LD 701) will flash in 5x groupings. Ive tried to look up what this blink code means, but am not getting anywhere.
          so in summation:
          TV picture went out. LEDs light up. sound OK
          Replaced Tconn board. TV still no picture. LEDs light up. sound OK
          Replaced logic board. No picture, no sound, and no LEDs. BUT standby light flashes 3x and debug light (LD 701) flashes in groups of 5.
          No obvious blown capacitors and voltages seem to check out.
          Im a mechanical engineer, so my electrical background is limited. Just trying to go from most common to least common problems.
          Any help would be appreciated. Thanks
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            So this means the replacement Main Bd. is either bad or the wrong one for your set. Your original Main Bd. is good. Put back in the original Main bd. and verify you are at the point where you started, TV power on, backlights on, no picture with audio. With the TV disconnected from the ac. remove the LEFT FFC from the T-CON Bd. to the Panel. Power on and see if you have half a picture. Unplug the TV from the ac and reconnect the LEFT FFC and remove the RIGHT FFC to the Panel. Power on and see if you have half a picture. Report your findings.
            • besetbyall
              • Jul 2018
              • 4
              Ok, so i put the old (original) logic board back in and did as you said. When unplugging the FFCs, the side that is unplugged goes solid white and the side still connected stays black.
              Volume, input changes can be heard, but no visual cues on either side. This is true for both sides. Attached a photo of dichotomy.
              • besetbyall
                • Jul 2018
                • 4
                Bump
                • iFixStuff
                  • Oct 2015
                  • 18
                  Originally posted by besetbyall
                  hi,
                  revival of an old thread, but was there any resolution to your issue? I'm having the same issue with an lg 50uf8300 set. Went through a bunch of the same checks as you (connections, capacitors, etc). Through i narrowed it down to the t-conn or logic board as the voltages seemed to check out on the legend listed on the power board.
                  Initially, the tv powered on, leds would illuminate, but no picture. Sound was there. Replaced the tconn board, same symptoms. Power on, leds illuminate, sound ok, but still no picture.
                  Recently replaced the logic board, and now the tv tries to power on, red standby light at the joystick will flash 3 times. And now similar to your initial symptoms, the debug light (ld 701) will flash in 5x groupings. Ive tried to look up what this blink code means, but am not getting anywhere.
                  So in summation:
                  Tv picture went out. Leds light up. Sound ok
                  replaced tconn board. Tv still no picture. Leds light up. Sound ok
                  replaced logic board. No picture, no sound, and no leds. But standby light flashes 3x and debug light (ld 701) flashes in groups of 5.
                  any luck on this set?
                    • 12268
                    • U.S.
                    May have bought a bad tcon?
                    • zomi
                      • Nov 2011
                      • 507
                      They have a few differrent panels for these
                      and hence a few diff boards
                      post pics of the main boards showing part numbers please.
                      could still be mainboard bad or tcon or badpanel.
                      • besetbyall
                        • Jul 2018
                        • 4
                        My last try was going to be the Main Board.
                        My first try was the T-conn, with no change.
                        Then the Logic board with slight change, but no picture still.
                        I did as andrew suggested above and got the results shown in the pictures.
                        Now my debate is the Power board.
                        Take a change, replace, and hopefully get a working set finally.
                        Or just invest in a new TV.
                        With the trouble shooting though, I now have a spare Tconn and logic board.
                        PNs:
                        Power Board - EAY64029601
                        Logic Board - EBT63972503
                          • 12268
                          • U.S.
                          Try heating the capacitors on the powerboard a little with a hair dryer, see if tv responds.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • ohren
                            by ohren
                            09-08-2023, 05:24 PM
                          • Yanleb
                            LG 60PK550 Logic Control Board EBR63450301
                            by Yanleb
                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                            C57: 3.30V
                            C61:...
                            07-20-2023, 12:38 AM
                          • korben_dallas
                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                            by korben_dallas
                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                            MY QUESTION:
                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                            02-14-2024, 12:23 AM
                          • Stephen
                            A2991 Logic Board issue, 20volts 0 amps help!
                            by Stephen
                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                            09-10-2025, 03:16 PM
