Vizio M320SR turns off after logo
  • Roush2fast
    • Jan 2017
    • 49
    Re: Vizio M320SR turns off after logo
    Originally posted by dick_barton
    Does the large capacitor still have 389V DC when the set is squealing and are all the DC output supplies still operating and is there still 13.7V on the IC A6069H between pin 3 & 5.
    If you disconnect the Inverter cable does the squealing stop.
    Only thing that yields a result is disconnecting the main board when in stand by. The squeeling stops then once reconnected the Vizio lights blinks indicating reset and the squeeling returns when the blinking stops.
    As far as your other questions yes everything seems to be performing optimally less the sound. l need the TV to fail again so I can test. I will run a load on it tomorrow and see how it goes.
    • Roush2fast
      • Jan 2017
      • 49
      OK the TV failed again. I have tested everything but the backlight lead. I am a little confused how to test this with the way the connection is labeled. Do I test each lead connected then disconnected when powered on ? Also , do I just test each lead grounded to metal chassis or use one of the NC pins. Another question is why does led 5 have two leads while 1-4 have one? How do I test led 5 ?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        So when it failed does the large capacitor still have 389V DC and is there still 13.7V on the IC A6069H between pin 3 & 5.?
        • Roush2fast
          • Jan 2017
          • 49
          Yes to both
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            So when it fails you still have 398V DC across the cap, 13.7V between pins 3 & 5 of A6069H, normal sound, picture on screen when using a flashlight to view?
            If so can you measure the voltage to chassis on all the pins of CN8501 connector at switch on. It should peak and then may drop very quickly.
            • Roush2fast
              • Jan 2017
              • 49
              Triple confirmed 389v at cap , A6069H fluctuates 13.5 ~ 13.8 , Normal sound and visible picture with flashlight.
              CN8501 Test Results
              LED 1 Peak 9.9v then drops to 0 when back lights turn off
              LED 2 Peak 9.9v then drops to 0 when back lights turn off
              LED 3 Peak 9.9v then drops to 0 when back lights turn off
              LED 4 Peak 9.9v then drops to 0 when back lights turn off
              Testing LED 5 yielded different results each time. Voltages were consistent on both LED 5 pins.
              Test 1 Peak 93v then drops to 38v when back lights turn off
              Test 2 Peak 89v then drops to 38v when back lights turn off
              Test 3 Peak 91v then drops to 18v when back lights turn off
              What do these results translate to ?
              • Roush2fast
                • Jan 2017
                • 49
                Anything ?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #28
                  Those readings suggest that you have a led problem or led problems. It could also be that the interconnections of the led strips behind the panel need to checked for poor connections.
                  Your next step is to look for Youtube video's on how to check the leds and led strip connections.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    this video may help you strip down the tv to the led strips
                    https://www.youtube.com/watch?v=NI9wOZKHOVE
                    and how to test the leds
                    https://www.youtube.com/watch?v=K_VfM4grw3I
                    once you get your set stripped down to the led strips post a picture and we should be able to show you the areas to bridge if you need to do it.
                    • Roush2fast
                      • Jan 2017
                      • 49
                      I get the same voltages with the led connector unplugged. Wouldn't that suggest a problem with the board ?
                      Also , the TV works properly for a few days after leaving it unplugged for 24 hours. Is this consistent with bad LED's ? I would think they either work or do not. I just want to be sure before I go through this step.
                      Thanks for the help Barton and Vince.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #31
                        I cannot guarantee that it is a led / led strip connection problem but all the symptoms you give above are leading me to that conclusion.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          intermittant faults are always hard to locate and find, at this point your ruling out possible causes as long as your really carefull with the lcd panel you should be fine but like any tv when disassembling any lcd panel theres a slight risk of damage happening.
                          • Roush2fast
                            • Jan 2017
                            • 49
                            I am comfortable with this process so I might give it a go. Is it down to power board or LED strips ? I can get a new power board for $26 off EBAY so I am considering trying it. If it's the strips they run around $65 and at that point I would rather buy a new TV. Well checking the LED's doesn't cost anything so I might as well check. Will post back results.
                            Thanks again
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              #34
                              You can wait and see what others may conclude before proceeding.
                              There are a lot of Youtube videos showing how to connect led strips together (bypassing any poor connections) by soldering wires across the connection points and also how to test leds using your multimeter.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                i was trying to find those videos and add links but could see any showing how to actually place the wire bridges but im on a small screen phone so its awkward to search on youtube etc.
                                • Roush2fast
                                  • Jan 2017
                                  • 49
                                  I will research and consider my options. Thanks again and I will post back results.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #37
                                    Testing leds
                                    Diagnosing faulty led/connectors
                                    https://www.youtube.com/watch?v=Bf5T2wwtydY
                                    • Roush2fast
                                      • Jan 2017
                                      • 49
                                      Well thank you sir
                                      • Roush2fast
                                        • Jan 2017
                                        • 49
                                        Well I was not expecting this configuration. The TV only has two strips at the top. All LEDs illuminate on power up. I tested the TV when it was working and all voltages were copacetic. In failure I have only 38v on led 5 pin and 0v on led 1-4 (cn8501). How do I test these strips and is it necessary seeing that all illuminate on boot before they shut off? Power board problem maybe ?
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #40
                                          How long do the leds stay on for before going off. Can you turn the backlights all the way down so you can see if any one led is not illuminating.
                                          • Super360
                                            Vizio E701i-A3 Vizio logo flashing then turns off
                                            by Super360
                                            Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                            07-25-2024, 07:06 PM
                                          • JaquesPratt
                                            Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                            by JaquesPratt
                                            I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                            This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                            07-16-2024, 01:04 AM
                                          • taslan
                                            Surface 7 Pro wont boot, shows Logo and immediately turns off
                                            by taslan
                                            as stated in the title, my surface 7 pro wont boot anymore.
                                            When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                            I dont even have a chance to get into bios or boot from usb.
                                            While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                            I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                            Bought it directly from microsoft and used it now and then and only...
                                            01-16-2025, 01:25 AM
                                          • USmechS
                                            Hisense 65H6570F Logo shows then turns off
                                            by USmechS
                                            Hello everybody,
                                            I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
                                            Things I have done:
                                            A. Plug it off and on.
                                            B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
                                            C. Contacted the customer service, They sent me a firmware update, with the file name:
                                            upgrade_loader_no_tvcertificate.pkg
                                            The zip file has this...
                                            04-25-2022, 03:06 PM
