SMPS P-SMPS Board for L37WD12
  • mstevens23
    • Jan 2017
    • 5
    I'm looking for the original CAP values for the P-SMPS Board for an RCA L37WD12. The board in question can be viewed here. I've replaced them once before and know I did not use the exact same values as the originals. If someone has the schematic for this board with the values or can at least give me what they are, I'd greatly appreciate it.
  • petehall347
    • Jan 2015
    • 4450
    Re: SMPS P-SMPS Board for L37WD12
    looks like you are needing the schematic for it . sams may have it .
    why did you change values and what is the problem now ? did it work after putting wrong ones in ?
    • diif
      • Feb 2014
      • 6978
      • England
      There is reference to that board on this page.
      https://contour07.wordpress.com/2011...2wd12-l37wd12/
      • mstevens23
        • Jan 2017
        • 5
        I changed values cause what I had on hand wasn't exact. The TV would not turn on unless I got it warm. Once it was warm, it would turn on and work flawlessly. I knew it was a sign of bad caps as I've been replacing caps in motherboards for years. Not sure what "sams" is.
          Sch.
          • mstevens23
            • Jan 2017
            • 5
            Thanks Budm. That's the one I was looking for in all of the other posts about this model. Now for a few questions to clarify what I'm reading on this schematic. I know that cp613 is 22 mfd 50v. I've got that down. From that I"m reading on the notes on the schematic it says that all voltages for caps are 50v unless otherwise noted. I'm looking at cp614 and cp615. 614 says "10U" and 615 says "680p". Am I to assume they each mean mfd for each or am I off center here. Thanks again.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5094
              • New Zealand
              C614 sounds like a 10uF (microfarad) and C615 680pF (picofarad)
              Using mfd or MFD for microfarad is a bit archaic now.
              Most people use uF (or correctly, μF) these days.
              mfd is too easy to confuse with mF (millifarad) which is also rare, but is an order of magnitude different!
              not to mention mmfd which is the same as picofarad...
              -David VanHorn
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Agree with the rest here, also what a nasty psu design so cramped poor thing must run very hot
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
