Sharp LCD LED TV LC-39LD145V [C] - Vestel 17IPS20S, problem with backlight
  • bbccbb
    • Jan 2017
    • 53
    • Croatia
    I have a problem with this LED TV power supply. Sometimes it powers down LED backlight. There is no way to predict when it is going to happen. Sometimes it works 5 hours. Sometimes backlight switches off after 10 minutes. Switching it off and on again solves the problem for some time (sometimes for few minutes, sometimes for few seconds and sometimes for few hours).
    I cannot reproduce the problem when needed… I have to wait for it.
    I've made some photos of the layout, Vestel power board and main board.
    I've also measured voltages on same points when the backlight is on and when it's off.
    Measurements were made only on the non-SMD side as I could easily access it.
    The radings of voltages betwen chasis and some points (https://docs.google.com/spreadsheets...it?usp=sharing):
    point V when working V when not working
    connector CN501 LED red wire 168 119
    connector CN501 LED black wire 25 21,7
    diode D504 C 164 118,8
    diode D504 A +++ 119,1
    J85 0 0
    C2582 - -0,02 0
    C2582 + 168 118,8
    J25 11,99 12,3
    J45 11,99 12,3
    J34 0 0
    resistor R574 right 120 119,2
    resistor R574 left 20 18,8
    J6 10,27 10
    J7 0,6 0,1
    Q216 E 10,5 10,5
    Q216 B 10,8 10,8
    Q216 C 10,1 10,3
    J94 -0,02 0,01
    J95 -0,02 -0,01
    J96 -0,02 -0,02
    F507 +++ 55,5
    F506 +++ 55,2
    D360 C 59 59,1
    D360 A +++ 119,1
    C316 + 119 119,1
    C316 - -0,02 -0,01
    J55 0,05 0,06
    J51 -0,02 -0,02
    J12 -0,02 -0,02
    C392 + 120 119,1
    C392 - -0,02 -0,01
    C317 + 120 119,1
    C317 - -0,02 -0,01
    D226 C 12,41 12,41
    D226 A -0,08 -0,05
    D225 C 12,41 12,41
    D225 A -0,08 -0,05
    D209 C 12,41 12,41
    D209 A -0,08 -0,05
    J30 10,27 10,21
    J42 -0,1 -0,1
    Q301 G 1,15 -0,2
    Q301 D +++ +++
    Q301 S -0,09 -0,1
    R320 top -0,09 0,02
    R320 bottom -0,09 -0,2
    C105 - -0,12 -0,1
    C105 + 215 218
    C534 - -0,12 -0,12
    C534 + 215 218
    Q211 G 0,4 0,4
    Q211 D +++ +++
    Q211 S -0,12 -0,12
    J20 215 218
    J81 215 218
    R235 top -0,08 0,03
    R235 bottom -0,08 -0,12
    D206 C 312 310
    D206 A +++ +++
    D506 C 214 217
    D506 A +++ +++
    D100 C 214 217
    D100 A 121 158
    Q100 G 1,52 0,23
    Q100 D +++ +++
    Q100 S -0,09 -0,1
    D115 C 122 161
    D115 A 61 74,3
    D114 C 61 74,3
    D114 A -0,08 -0,08
    D113 C 122 160
    D113 A 61 73,4
    D112 C 61 73,4
    D112 A -0,08 -0,08
    C212 + 12,4 12,4
    C212 - -0,02 -0,01
    C211 + 12,4 12,41
    C211 - -0,02 -0,02
    C210 + 12,4 12,41
    C210 - -0,02 -0,01
    C209 + 12,4 12,4
    C209 - -0,02 -0,02
    J71 -0,02 -0,02
    J66 -0,02 -0,01
    J49 0,04 0,09
    J17 0,04 0,04
    J78 0,04 0,02
    J50 119 119,2
    J52 119 119,2
    Any ideas?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp LCD LED TV LC-39LD145V [C] - Vestel 17IPS20S, problem with backlight
    Connectors that link led strings are breaking down, open panel and bridge over them with solid wire.
    • CapLeaker
      Leaking Member
      • 8327
      To add to Reecey's comment: Turn down the backlights to next to nothing and see if the backlights stay on longer. If it does, then you have a problem with the backlight LED's.
      • koka0011
        • Apr 2013
        • 30
        • Sri Lanka
        it could be a faulty component in inverter.use hot air gun to heat up the inverter area.and measure the voltages ERR pin.try to measure ERR pin voltage and heat up the inverter area and check the voltage when it stops.you can find the bad component using heat up method
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The voltage across C105 should be 400V otherwise the FAN7529 is not operating.
          Check diodes D101, D102, D506, Q100
          What DC voltage do you have (carefully) between pins 8 & 6 of FAN7529. Check C127
          Edit
          What does Q100 D +++ +++ mean?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I dont think he measured across the caps right DB thats why he has a low reading. These sets wont run if the fan Ic isnt working.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Thanks. Didn't think of that. Just considered that the readings were taken when the backlights were off.
              • bbccbb
                • Jan 2017
                • 53
                • Croatia
                Edit
                +++ means that my voltmeter said "higher than 600".
                • bbccbb
                  • Jan 2017
                  • 53
                  • Croatia
                  Ok... I'll do that. Thank you.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    When you lose the backlights are you also losing sound etc or just backlights.
                    When the backlights go off can you measure using your meter set to DC, the voltage between the two legs of C105 (meter probe either side of C105) which should be about 380 -390V
                    • bbccbb
                      • Jan 2017
                      • 53
                      • Croatia
                      As I said before... there is no way to tell when it will turn off backlights. Sometimes it takes hours.
                      On one occasion it switched of backlights after 10 minutes. I've turnd the TV of and on again and it worked for 5 hours more. That's why I do not see hot to trigger this myself.
                      When you wrote "Turn down the backlights..." you ment using menues on the TV?
                      So, you say... if the same thing happens after soldering connections to the LED strips, then I have to wait for LEDs to stop working?
                      • bbccbb
                        • Jan 2017
                        • 53
                        • Croatia
                        Only backlights. Sound working. Picture on.
                        Ok... I'll do that. But I'll have to wait for few hours.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          You can ignore my previous request. If the sound is still working then as ReeceyBurger123 has already said the power supply is working otherwise you would not have sound.
                          • bbccbb
                            • Jan 2017
                            • 53
                            • Croatia
                            So... then I have to make a better connection (directly soldering to the connector) to LED strips and then wait for some LED to fail. Right?
                            • CapLeaker
                              Leaking Member
                              • 8327
                              yeah... turn down the backlights using the Menu on the TV.
                              • bbccbb
                                • Jan 2017
                                • 53
                                • Croatia
                                This would work if at some point TV would hold the backlight on for short time and I could test if it would work longer on lower energy consumption (or less heat on sam poart). But I do not get that. Once I turned of after 10 minutes. I restarted TV and it worked for 5 hours... I went to sleep and turned it of that night.
                                It would be better it it would stay dark all the time! I cannot deduce the problem from all this. That's why I asked for any pointers.
                                I'll make a fix connection between power leads and LED strips tomorrow. I think it will take me few hours. I'll have to be careful removing that LCD... if I brake it...
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  this video shows the type of repair you may have to do some strips i think are joined in the middle to so you may have to bridge them to, intermitant faults like this are always hard to find but do take care removing/replacing the lcd and do keep the diffuser sheets in the rite order and also try to keep away any dust/finger print free as best you can as these show up when the set is working.
                                  https://www.youtube.com/watch?v=AeAGI0yNgEM
                                  • bbccbb
                                    • Jan 2017
                                    • 53
                                    • Croatia
                                    The guy on the video just removed the whole back metal cover with LEDs strips on it and plastic reflectors. That means that I could put my TV with LCD facing down on the table and leave a diffuser sheets on it.
                                    Then I can solder all the bridges and reconnect all the connectors and that will be it.
                                    Then I will have to test it to see if that was the cause off my backlight turning off.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      all tvs are diffrent too disassemble etc so its whatever is the easiest on that make of tv re assembley is hard ive cracked a screen when clipping the black plastic surround back on so be really carefull and take it slow thats all i can suggest.
                                      • bbccbb
                                        • Jan 2017
                                        • 53
                                        • Croatia
                                        Ok... I soldered all the joints. I'll post the photos of what it looked like. Now I'll wait to see if this solved my problem.
                                        • 90Ninety
                                          Crappy Vestel/Sharp LC-40FG3141K Set Backlight going off randomly
                                          by 90Ninety
                                          Hello
                                          Model Code Sharp LC-40FG3141K
                                          Firstly perhaps I should save myself the agony and throw this set out ? Then again I hate E-waste , or giving a person further headace in the far east or Agbogbloshie . So I digress to my last hope of fixing this pile of shite , with the dash of hope from your combined experiences
                                          So this set is randomly turning off its backlight ( could be days, hours, minutes or seconds ) , my research suggests this maybe an over current protection , or leaky/faulty LEDS , or a bad LED driver circuit . So I opened it up , stabbed my Multi...
                                          07-06-2022, 07:09 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • hazi12
                                          Vestel main board 17MB140TC
                                          by hazi12
                                          Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                                          Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                                          I can send a dump....
                                          10-01-2025, 01:28 PM
