Insignia NS-50D550NA15 dead
  • Prop1
    • Jun 2014
    • 93
    Hi guys, long time between TV issues. I got this Insignia that is dead. Checked for the 5v standby and it wasn't there, verified the fuse on the PS board was good. Am I correct to assume this is the PS board? I've also noted on ShopJimmy that the LED strips could be bad. Does one being bad rule out the other? Anyway of testing the LED strips without buying the PS board first?
    Thanks for any help!
    Re: Insignia NS-50D550NA15 dead
    Disconnect all other boards that are connected to the power board and then apply AC to the power supply board to see if the stby Voltage is present or not.
    SJ sell LED tester.
    http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
    • Prop1
      • Jun 2014
      • 93
      Will do. Thanks!
      • Prop1
        • Jun 2014
        • 93
        Disconnected everything from board and applied AC.
        STB =0v
        12v =9.52v
        16v =0v
        Board and/or time to check LED strips? Thanks.
          Hmm, I need to see the pictures of the board.
          I believe the STB pin on the power supply board is the same PS-ON pin, not standby power supply pin. So I need the pictures to verify what the STBY Voltage pins are.
          • Prop1
            • Jun 2014
            • 93
            I'll upload pix tonight.
            • Prop1
              • Jun 2014
              • 93
              Here's pictures of the whole back, PS board, and the connector pinout info. This board is a Hisense 170452.
                Hisense/Insignia 170452 Power Supply Unit
                http://www.shopjimmy.com/hisense-170...pply-unit.htm#
                Pictures provided by shopjimmy.
                The standby power is 12V, not the typical 5V, so please verify that 12V to see what you really have when there is no other boards connected to the power supply board, and when all the boards are connected to the power supply board.
                12V = 12V STBY SUPPLY
                STB = PS-ON, to turn on the 16V and 12V supply (once main supply is on, the 12V from main supply is used to provide the 12V instead of 12V from stby supply).
                SW = BL-ON
                BTW, when you check the STB pin DCV, do you have all the connector in place?
                I see you have 9V connector attached to the cables that go to the main board.
                • Prop1
                  • Jun 2014
                  • 93
                  I'll recheck voltages and get back with results. 9v connector was just for probing the cable connector.
                  • Prop1
                    • Jun 2014
                    • 93
                    Here are the voltages with ps disconnected: 12v = 9.53v, stb = 0v, 16v = 0v, sw = 0v, pwm = 0v.
                    Voltages with ps connected (all connectors in place): 12v = 12.3v, stb = 3.35v, 16v = 0v, sw = 4.07v, pwm = 4.13v.
                    Thanks again for your help!
                      OK, the switched 16V power supply is not working.
                      No power to TV and all the boards are still connected, then check the resistance between GND pin and the 16V pin to see what kind of resistance you have.
                      • Prop1
                        • Jun 2014
                        • 93
                        I'm effectively charging a cap.
                        • Prop1
                          • Jun 2014
                          • 93
                          I did some monkeying around and got the TV up and running. The picture has a gray background with 2 horizontal black bands at the 1/3 and 2/3 up the screen points. The 16v is running at 18.5v.
                            So what did you do to get the 16V Switched supply to work?
                            So you do have images on the screen or just grey screen with lines? If it is just grey screen then the T-CON board is not working.
                            "I'm effectively charging a cap." What does that mean?
                            • Prop1
                              • Jun 2014
                              • 93
                              Forget that about the picture with the lines. I was half asleep when I made that non-discovery. The screen is totally black...and very reflective.
                              When I state that "I'm effectively charging a cap", the resistance starts at near zero and climbs over time to into the 10s of Kohms. But something did change after probing the ps board checking caps, diodes, and transistors. Here are the numbers now, TV off: 12v=12.37v, stb=3.35v, 16v=18.5v, sw=4.08v, pwm=4.13v and with the TV on (solid red indicator): 12v=9.4v, stb=.05v, 16v=.02v, sw=.02, pwm=.02
                              Main board issue? Blown LED strips?
                                TV OFF. TV ON reporting are backward?
                                12v=12.37v, stb=3.35v, 16v=18.5v, sw=4.08v, pwm=4.13v These readings should be for TV ON. iF If that the case then you do have all the correct Violtages and correct command Voltages. So YOU DO NOT have Backlights, right? If that is the case then we need to start check to see what DCV you have feeding the LED strings.
                                • Prop1
                                  • Jun 2014
                                  • 93
                                  Yes, that is correct. Those voltages are when ON. No backlight is seen.
                                    You need to put black probe on the chassis, red probe on one of the two pins of the LED connector (LED connector in place) then turn the TV on and observe the DCV reading, wait a couple seconds to see if the Voltage drops down, then turn of the TV and then move the read probe to the other pin of the LED connector, turn the TV and observe the DCV reading again.
                                    • Prop1
                                      • Jun 2014
                                      • 93
                                      Red lead = +240v {fluctuates +/- 10v}
                                      Wht lead = -107v {solid}
                                      Both to chassis gnd.
                                        240V, that sounds like you have no load (LED strings has open circuit). As you can see, the filter cap C955 for the Boost converter circuit is only rated at 250VDC (33uF), so 240V is pushing it.
                                        You need one of this:
                                        • k370
                                          Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                          by k370
                                          I have a NM-A321 board that is dead, with no power at all.
                                          When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                          With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                          • +3VALW
                                          • +5VAUX
                                          • 1.2VSUS_PWRGD
                                          • 3VALW_PGD
                                          • 1.05VAUX_PWRGD
                                          Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                          The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                          09-23-2024, 11:57 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • corrize
                                          Nikon D5 – dead, power board issue ?
                                          by corrize
                                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                          Now, I try to understand how it works.
                                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                          04-03-2023, 09:13 AM
