Insignia NS-50D550NA15 dead
  • Prop1
    • Jun 2014
    • 93
    Re: Insignia NS-50D550NA15 dead
    Originally posted by budm
    240V, that sounds like you have no load (LED strings has open circuit). As you can see, the filter cap C955 for the Boost converter circuit is only rated at 250VDC (33uF), so 240V is pushing it.
    You need one of this:
    http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
    So the question is; buy a tester (that will likely only be used once) for the cost of a set of LED strings, or just buy the LED strings...
      Well, you will have to disassemble the panel to verify the exact type of LED strips you have (you have look up the LCD panel model number of your panel), it can also be bad connectors between the strips.
      I do not know if your panel is edge-lit or back-lit.
      • Prop1
        • Jun 2014
        • 93
        I'll start taking it apart as I find the time over the next couple days and see what I find. Thanks.
        • Icomratt
          • Mar 2017
          • 6
          I have a Hisense 50h3 with Pwr-171497 HLL-4855wc Is this Board lost it happy smoke?
          pwr off 12:=.02 16:=12.04 pwm3:=20.7 3ds:=0.0 xp901:=.20 stby:=.02
          Pwr on 12:=4.9 16:=12.03 pwm3:=23.4 3ds:=3.4 xp901:=1.29 stby:=2.9
          • Icomratt
            • Mar 2017
            • 6
            170 volt dead! The r904, r965, r966 not readable next to Q807
            Same for Q806 r961,2,3 fried! Any one have the values?
            Thanks!
              You should start a new thread with make and model for the name of the thread and you must provide good clear pictures of the whole backside of the TV showing all the boards and good straight shot top and bottom side of the board, pictures must be clear enough to read the connector pins labels.
              It looks like you count the pins wrong so those Voltages are not correct.
              • Icomratt
                • Mar 2017
                • 6
                Will do Thanks!
                • k370
                  Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                  by k370
                  I have a NM-A321 board that is dead, with no power at all.
                  When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                  With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                  • +3VALW
                  • +5VAUX
                  • 1.2VSUS_PWRGD
                  • 3VALW_PGD
                  • 1.05VAUX_PWRGD
                  Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                  The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                  09-23-2024, 11:57 AM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • corrize
                  Nikon D5 – dead, power board issue ?
                  by corrize
                  Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                  When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                  I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                  Now, I try to understand how it works.
                  There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                  04-03-2023, 09:13 AM
