Lg 50ln5100-ub
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lg 50ln5100-ub
    You only need to cover those pins that return the picture to normal. Try and keep as many of the pins in use.
    I have seen this trick done but do not know what if any the long term effects are.
    Post a picture of the final results of the screen.
    • Diah
      • Feb 2013
      • 6608
      Re: Lg 50ln5100-ub
      Originally posted by Fisher77
      Ok, the new t-conn came in this morning. Installed it, and of course the same problem which confirms a panel fault. I tried the tape trick. I had to cover 12 of the left tracks, on the right ribbon cable to get a normal picture again. Thanks jjannsen7 for the trick.
      did you forget ? this was yours fault caused the taps of panel bad
      I took a heat gun and heated around the edges of the panel with no change.
      Originally posted by Diah
      your first post photo there are horizontal line.. and your first test by release ribbon from panel one by one, you have clean white picture. also when you each time release these ribbon it will display different color line. those are enough to tell T_CON Fault .. try replace it before you caused more damage to the set.
      to whom read this post later...
      always 99.9% horizontal line on screen are T_CON or LVDS issue. panel don't have any to do with this fault.. only UHD TV of Samsung it would be panel fault.
      • Fisher77
        • Feb 2016
        • 229
        Re: Lg 50ln5100-ub
        Thanks dick_barton. Anything other than tape I can use?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Re: Lg 50ln5100-ub
          As I have said I've never done it, only seen Youtube videos. I would think the thinner the tape the better so as not to damage the connector when closing it down and to ensure you still have contact with all the other connections when closed.
          • jjanssen7
            • Nov 2012
            • 252
            Re: Lg 50ln5100-ub
            Thin tape is the best. I've done this to 30-40 different units and not have one come back (I offer warranty). I do believe it's a "bodge", but the only other option at that point is to toss the whole thing.
            Sometimes the best you can do is get the picture to stabilize and have one thin horizontal line which I believe reveals where the short is.
            In my experience it doesn't work for many tvs, especially those with flexible side tabs that extend out from the screen. Just a few LG, Sony and the odd Samsung that present with the problems you had. It's a last resort, after confirming that LVDS, Tconn and Main are in good working order.
            Let us know how long it lasts!
            • jondoe
              • Nov 2016
              • 547
              Re: Lg 50ln5100-ub
              That horizontal tearing looks very similar to the problem I had on the one I just "cooked", it was the XD chip on the main board.
              • jjanssen7
                • Nov 2012
                • 252
                Re: Lg 50ln5100-ub
                When possible I've confirmed it was a panel problem. Swapped the main board with a known working one and had the same problem.
                • Fisher77
                  • Feb 2016
                  • 229
                  Re: Lg 50ln5100-ub
                  Ok, let me run this by you guys. With the ribbon cables connected from the
                  t-conn to the panel (no Tape), and I check the voltage on the 2 test points on the t-conn (with the red squares in the picture), they both cycle constantly from +30V to -4V. Everytime the voltage cycles, the picture changes on the screen, but there are still lines on the screen at both voltages. With the ribbon cables disconnected from the t-conn to the panel , the voltage still cycles from +30V to -4V.
                  Now what I am wondering here is, if the ribbon cables are disconnected fom the t-conn to the panel, doesn't that eliminate the problem if it were a panel fault?
                  If so, would that indicate a main board fault since the t-conn has been replaced, and the old t-conn was showing the same voltages when I probbed the test points on it?
                  • jjanssen7
                    • Nov 2012
                    • 252
                    Re: Lg 50ln5100-ub
                    If there are lines on the screen with both voltages, doesn't that eliminate the voltage change as a cause/symptom of the lines?
                    • Fisher77
                      • Feb 2016
                      • 229
                      Re: Lg 50ln5100-ub
                      Damn, I didn't think about it that way. Good point jjanssen7.
                      • Fisher77
                        • Feb 2016
                        • 229
                        Re: Lg 50ln5100-ub
                        Well it is taped now. I had to cover 12 tracks of the right ribbon cable. It still has a slight twitch in it, but with a movie going it is barely noticable. If I tape over 13 tracks, the twitch is gone, but it has a line on the screen.
                        Thanks jjanssen7 for cluing me in on the tape trick
                        Thanks for all the help everyone.
                        • motanya
                          HP 820 G3 Dots/Blurry Screen
                          by motanya
                          Hp 820 G3
                          6050A2725001-MB-A01
                          This laptop has dots that show up once on the windows login screen. The bios menu and windows loading phase doesn't have them.
                          What I have tried:
                          change screens but it's not a screen issue as they show on internal and external display.
                          Changed SSD and Windows
                          Wrote a new bios
                          Inspected if there is anything unusual on the board, none
                          Has someone seen this before, what could be the issue...
                          03-21-2025, 11:32 AM
                        • platinumsteel
                          HP 14-dq2088wm 11th Gen Missing 3V/5V Standby Voltage
                          by platinumsteel
                          Hi guys have a HP 14 Labtop. DA0PAHMB8F0 .There is no White LED on the DC Jack .It got a drop of water damage right next to the 3V IC ( Silergy SY8386BRHC) and corroded a resistor and a pad which belongs to the Enable for the IC. I cleaned the area and re-soldered the resistor. Nothing Changed. I don't know what the value for the resistor should be.It measures about 80.0K No schematics available for this model. A good friend on here mon2 helped me identify the IC markings and gave good advice on making sure to measure the input voltages and enables and checking for short.
                          There is no short...
                          11-12-2024, 05:49 AM
                        • slap_happy
                          Help identify components from blurry FCC photos?
                          by slap_happy
                          The first photo is of my sample device which lacks the two components that I wish to identify.
                          The second (very blurry) photo is of the same model device submitted to the FCC, which does contain the two components I wish to identify.
                          The board for the device is configured for a USB 2.0 A port, but the port is not installed at the factory. But it does work if installed.
                          However, the power pin does not supply voltage because the two components in question are not installed in produced units.
                          One of the two components (6C6) is obviously a capacitor....
                          01-24-2022, 01:06 AM
                        • paulstef
                          Weird blurry -no-picture on Plasma TC-P60S30
                          by paulstef
                          Hi
                          This TV has no picture, or nothing that resembles a real picture, just some slowly changing blurry forms and pixels. It ends up having a jumping white square in the middle, presumably the "no source connected" message, I guess.
                          Front LED turns on normal. Vsus is 209.8V. +15Vc is ok also.
                          Power semiconductors on all boards tested, ok. SS and SC board LEDs are lit. (Tnpa5400 and Tnpa5399)
                          I should mention the TV was extremely dusty when I got it.
                          What else could I test?
                          Thanks...
                          12-23-2020, 03:30 PM
                        • paparazzo79
                          Samsung A6 tablet ,Bright blurry white spot on black background on IPS screen
                          by paparazzo79
                          Hi friends.
                          Noticed on purchased used A6 tablet from Samsung.
                          So is it smth serious or nothing to worry about?
                          Will it get worse?...
                          10-23-2021, 11:15 AM
