Vizio E422VLE screen problems when cold started. Works fine after 20 minutes.
+ More Options
Posts
  • SdlewisSr
    • Oct 2015
    • 146
    Re: Vizio E422VLE screen problems when cold started. Works fine after 20 minutes.
    Before I used the hair dryer on the tab I used a 5mm nozzle and 2mm nozzle (see attached image) on my SMD rework station to heat the PCB. I heated each SMD on the PCB. It was when I used the 5mm nozzle on the tab that I discovered that heating only the tab fixed the problem. I took my time holding the 2mm over each component on the PCB with no effect. I was not heating the PCB when I used the 5mm on the tab. When I heated the PCB end of the tab, there was no effect. Only when I heated the panel side of the tab did I discover that the tab was the issue. I used a hair dryer in the video only because it was easier. I tried pressing lightly on the tab to see if maybe using a shim would work but it had no effect. I will try to find the thread that you suggested.
    • vinceroger69
      • Mar 2012
      • 6714
      thanks for the update i have included the link for the tab bond fix in my last post there are also some guides on youtube basically it involves putting a shim over the tabs so when the sets assembled it puts pressure on the faulty tab bond, has the ribbon cable between the pcb and lcd panel have a small ic on? cof (chip on flex) as that may have bad solder etc hence working whilst heated.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Take your time and you should be successful with the fix. As Vinceroger69 says there are some good Youtube videos to guide you.
        • SdlewisSr
          • Oct 2015
          • 146
          Thanks. I will try. However, it may be a couple of days before I can get back to the TV.
          I really appreciate your help.
          Have a blessed day.
          • SdlewisSr
            • Oct 2015
            • 146
            I have tried pressure on the tab/lcd glass bond and it has no effect. Pressing on the flexible part of the tab itself has no effect either. Therefore I assume a shim would not help. I have included some photos of the tab. There appears to be an IC on the tab (cof) as vinceroger69 mentioned. Since my last post, I reassembled the TV to determine if I could just use the TV as is by heating the corner with a hair dryer before turning it on. Fully assembled I can heat the LCD glass in the corner near the tab for 10 secs and it works when I power it up.
            Have a blessed day
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              certainly a odd fault as budm has fixed this fault himself with shims maybe he will have a idea if it will work on your set
              • SdlewisSr
                • Oct 2015
                • 146
                If I am reading the budm thread correctly, it seems like the opposite problem to the one I have. It appears that budm was trying to transfer heat away from the tab, but I need heat to go to the tab.
                I can live with using a hair dryer for a few seconds before I turn the TV on. Normally, when I turn a TV on, it will be on a few hours anyway. I just would like to understand what is exactly happening for future reference.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #28
                  If putting light pressure on panel / pcb ends of the ribbon is not doing it, then try light pressure on the IC (COF) in the middle of the flexible tab.
                  Wherever you are warming up with the hair dryer is expanding the contacts due to heat resulting in making a good connection.
                  • SdlewisSr
                    • Oct 2015
                    • 146
                    I tried pressure on the flexible part of the tab, including right on the COF with no effect.
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • paqman
                      Vizio M60-C3 black screen
                      by paqman
                      So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                      So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                      03-02-2024, 04:37 PM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
