Samsung un75f6300- upper half of screen is dim
  • topfli8979
    • Oct 2012
    • 311
    Have a 75 in Samsung TV,. Panel is operating, can see picture throughout the display, no lines. Only issue is upper half of screen is not as bright as bottom. LED strips bad or component failure on a board?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung un75f6300- upper half of screen is dim
    I would initially suspect the led's or possibly the led controller. Can you measure the voltages on the led connector and post with a picture of the board.
    • Shaggybamboozle
      • Nov 2016
      • 11
      I have same issue but it also has a definitive line that seperates the dim from the normal.
      I will check backlight voltages and post the findings.
      It's just this TV is physically harder to move around for repair
      Cheers
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It will be interesting to see what you find.
        • JeffJ
          • Apr 2012
          • 189
          I just fixed a similar model, I was sure the LEDs were bad in the edge lighting, i tore the whole thing down and tested every single LED ok, was STUMPED, as the PSU appeared to be fine. I re-soldered the transformer that powers the 4 PWM banks for the edge lighting and the tv is fine now.
          Give that a go, its worth a shot.
          • skinner
            • Jun 2013
            • 54
            I had the same issue and I wanted to share my experience with everyone. I swapped the top and bottom connector for the backlights on the power supply but still had the same issue so I was able to rule out the PSU. Suspecting backlights I took the panel apart and there was my issue. I think I have a back light issue.
            • saddle_au
              Waste Warrior
              • 121
              Hate to jump in with a non-fix comment, but do you think a single led has allowed the plastic reflector sheet to catch fire? It looks like a led in the middle has also started to burn through.The edge burn in image 4 looks like a cable or joint fault.
              Unless that unit has been dunked in sea water or something else very unusual, I'd be sending Samsung those images immediately. Local to us, Samsung Washers have caused double digit home fires here due to condensation (I think) issues and high voltages.
              • JasonCO
                • Nov 2017
                I am having the same problem with my unit- mine is right in the middle of the tv- all the way across. haven't yet took it apart yet.
                • zomi
                  • Nov 2011
                  • 505
                  Ouch thats looks terrible
                  Its crazy that such thngs are allowed to happen to the consumers and there is no recourse with the manufacturer...
                  And they in turn milk us dry on replacemnt sets..
                  • noled
                    • May 2018
                    • Nederland
                    Hello I have the same problem , and like to share what I found.
                    -My Samsung ue75F6300 has a gray band in the middle of the screen.
                    After taking apart the tv, I found 3 strips not working.
                    ( a strip is made out of 3 strips D2GE-750SCA, sSCB & SCC)
                    measuring the voltage on the burning led strips gave me 75V and 0V on the not working strips.
                    voltage on the 2 connectors from the power supply was 330V (on pin B2 en B4).
                    Ruled out PSU because of the same readings on the 2 connectors (one for the top 6 led strips and one for the bottem half). and the top half leds worked fine
                    Removed the 3 not working strips and changed them 1 by 1 with a strip on a function set of 3 strips.
                    Only one strip was not working !
                    if one of the strips is not ok, 3 strips don't light up .
                    in fact only 1 led on the last part of a strip was broken !!
                    I'm waiting on new strip , and let you know how it turned out.
                    Hope this helps to someone with the same problem.
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Tom C
                      Samsung QN55Q70AAFXZA Half Screen Dim
                      by Tom C
                      I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                      Any suggestions would be appreciated.
                      thanks.
                      09-19-2024, 07:22 PM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                      by JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                      Please help. Thanks in advance!
                      08-12-2025, 11:45 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
