sanyo model FV3982 intermittent sound but no picture
  • Dan Surra
    • Dec 2016
    • 36
    this TV works fine for a while and then goes to a black screen. Tore the back off of it and cant see any obvious problems. Any advice?
  • Dan Surra
    • Dec 2016
    • 36
    Re: sanyo model FV3982 intermittent sound but no picture
    ok, I ran TV out of the outside case for hours. It worked fine and never went to a black screen with sound only. Only variable is that the garage is cool, around 50 degrees. I added some ventilation holes with a drill in the back near the boards and put it back together. I now have it playing in the house where it is warmer. So far, so good. Did anyone ever run into this problem?
    • vinceroger69
      • Mar 2012
      • 6714
      in a few threads people have also added pc fans to tvs to keep them cool etc maybe if the set plays up again heat one board at a time with a hair dryer untill the set shuts off then concertrate on that board by heating a smaller area to track the faulty part.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        This is shit aint it. Nothing to help. You want us to guess the fault ?
        • petehall347
          • Jan 2015
          • 4450
          • United Kingdom
          Only variable is that the garage is cool ..piffle ..
          how did it get there ? was the back removed making things more flexible before or after you moved it ? ..
          if i was to guess it has a bad connection that will come back later ..
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • nickgronk
            iMac PowerPC G4 very low sound • Sunflower Model
            by nickgronk
            Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
            I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
            I cannot find any schematics...
            08-05-2024, 07:04 AM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
