Samsung PN51F5500AFXZA issue - Power board thermistors cooked?
  • devheart
    • Jan 2017
    • 5
    Hi everybody. I recently acquired this 2013 Samsung Plasma TV, model PN51F5500AFXZA for free because it wasn't working. The red LED just continuously blinks when plugged in.
    The thermistors on the power board look cooked, with some discolouration of the PCB around them. I've attached an image of the board. The thermistors show as shorted when connectivity tested with multimeter.
    I tested all the diodes I could see, they all appear working, no shorts. No bulged caps. Nothing else looks shorted or burnt out. The fuse looks fine and tests shorted with continuity.
    Power board is: P51FF_DSM PSPF361503A
    Should I try replacing the thermistors? I found this part number for thermistor for this model: 1404-001224
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: Samsung PN51F5500AFXZA issue - Power board thermistors cooked?
    thermistors do run warm . they should lower resistance as they get warmer ..look up the spec sheets .. they probably start about 2.5 ohms at room temp.
    • devheart
      • Jan 2017
      • 5
      With the back off, I can hear a click and a high-pitch tone coming from the power board, when the LED blinks. It appears it's trying to boot itself up to some point, maybe a self check, when power is applied, but there's some issue.
      Anybody have an idea on whether it's a power supply board or main logic board issue?
      Thanks!
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        try unplugging the main board and see if back lights come on .
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I wouldn't advise you run it, thermistor normally blows if there is shorted fets.
          • devheart
            • Jan 2017
            • 5
            Tried plugging it in without main board. No backlights came on and no click from the power board.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Service manual which may be of help.
              Thermistor details
              Manufacturer Samsung
              Part Number 1404-001224
              Description THERMISTOR-NTC;10K ohm
                10K Ohms, that can't be right for the Inrush current limiter NTC, they are usually around 3~5 Ohms range..
                • petehall347
                  • Jan 2015
                  • 4451
                  • United Kingdom
                  is the inrush thermistor the black one next to power socket ?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    It's the two green devices at the bottom of the picture in post #1
                    • petehall347
                      • Jan 2015
                      • 4451
                      • United Kingdom
                      whoops yes .. black one is varistor ..i just found a schem but only shows one thermistor at 5ohms nt811s .. mustn't be correct schematic ..
                      • Nick's Tvs
                        • Jan 2014
                        • 621
                        That power supply is most likely fine. It rarely goes out. With power disconnected and voltages at 0v check the resistance between VS and ground. You may find it to be shorted due to a bad X or Y sustain. If not check the transistors on those boards for shorts to ground.
                        Also pictures of the back of the set would help.
                        • Asraf Atb
                          by Asraf Atb
                          01-27-2025, 05:02 PM
                        • Cooperr
                          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                          by Cooperr
                          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                          10-21-2025, 01:11 PM
                        • ohren
                          by ohren
                          09-08-2023, 05:24 PM
                        • C152Heavy
                          by C152Heavy
                          Summary for TL-DR readers:
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
                        • joliver82
                          Sony XR-65A95L no power due to logic board issue
                          by joliver82
                          Hi guys!
                          I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
                          First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
                          When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
                          Today, 04:57 PM
