Samsung UN60F8000BFXZA Backlight issue - Board BN44-00656A
  • JA64Flyers
    • May 2015
    • 7
    Hello all! I've searched around on the forums for info regarding the above samsung and PSU/LED board, but haven't found any exact matches. The boards look pretty different from their predecessors so i figured i'd put this all out there.
    The issue has to do with the back light. It will run perfectly for hours, even days, then the backlight kicks out until you change the source or power cycle the TV. Then it may come on for 5 minutes, or a few more hours. Its pretty random, i haven't found any patterns with it yet.
    Since there's a picture, the internet tells me the TCON board is fine. Next is checking the power supply / LED controller (all one board here). I haven't been able to find a schematic or diagram for this thing, to tell me what my voltages should be or what points i should meter from. I understand that if i get normal voltages with the LED's unplugged, but wrong voltages with them plugged in - then it's an LED problem. If the opposite is true, its a power supply problem (cross my fingers).
    Does anyone have any advice for getting that information? Thank you for your time!
  • CapLeaker
    Leaking Member
    • 8352
    Re: Samsung UN60F8000BFXZA Backlight issue - Board BN44-00656A
    Can we see the whole back side of the TV with all the boards connected?
    First I'd see what happens to the BL-on (back lights) signal on the PSU (may be called BLUon/off) that comes from the main board. Is the BLon still present (something like 3V DC), when the back lights go off?
    Next: Turn your back lights waay down to 40% or less and see if the back lights stay on longer. If they do stay on longer you have a LED problem and your boards are fine.
    • JA64Flyers
      • May 2015
      • 7
      Hey CapLeaker, thanks for the reply!
      Attached is a picture of the full back and the connector you referenced with BLUONOFF. I'm having trouble metering the voltage from pin 20 without unplugging the connector, i'll get creative and fasten a paperclip to my meter lead or something. I can probably get in next to the pin.
      Right now with the connector unplugged, it reads 4.5 vdc. I'll see what it goes to when the back light shuts off.
      • JA64Flyers
        • May 2015
        • 7
        More news! I can recreate the backlight going out by tilting the TV. When i tilt it forward about 20 degrees, it typically goes out. When it's laying down, backlight dead or alive, that pin reads 4.9 vdc. When i right the TV straight up and switch to another input (or powercycle, whatever "refreshes" the screen) it brings the backlight back.
        Right now, i lowered the backlight brightness like you suggested, and it seems to have passed my "laying over" test and is running still. I'll let it go for another hour or so to confirm.
        This leads me to believe there's a faulty connection in the LED strip somewhere. I've seen tutorials for other samsung models, any idea how i can tell how many strips i'll need to replace them? Is 4 strips common?
        *Edit: putting any pressure on the back of the tv or lifting the corner can cause the problem to happen. Pretty much confirms the hypothesis in my mind.
        • CapLeaker
          Leaking Member
          • 8352
          I think you are on the right track.
          • blowell
            • Jan 2021
            Hello everyone. I'm also debugging a backlight problem (video passes flashlight test, audio works, HDMI to PC enumerates as generic PnP monitor, etc.). I know main board is good and T-con board is good.
            Does anyone here know which pins on CNL802A and CNL802B have the symmetric high LED driving voltage? And what should that driving voltage be (~170V?)?
            Bob Lowell
            • blowell
              • Jan 2021
              I think the high drive voltages are probably on the pins labeled "+" in silkscreen.
              Does this sound correct?
                Bob Lowell
                The expected Voltages are shown on the Voltage chart printed on the power supply/LED driver board.
                https://www.badcaps.net/forum/attach...6&d=1483376884
                The picture is too blur to read the prints.
                the + is the Anode of the LED string, the - is the Cathode of the LED string.
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • Cooperr
                  Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                  by Cooperr
                  I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                  The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                  10-21-2025, 01:11 PM
                • ohren
                  by ohren
                  09-08-2023, 05:24 PM
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
