Philips 46pfl5505d/f7 dead
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;i have here an lcd tv that i'm trying to save that i found in the dumpster,
    Philips 46pfl5505d/f7 that is completely dead, no standby led no voltages at Cn2'
    i checked Diodes in circuit ZD951,D950,D951 and all are short in circuit,
    i took them all out of the circuit and tested them and only D951 is short out of the circuit ,if i replace D951 will it fix the tv or do i have to look up for other bad components? Thanks and Happy New Year to you all.
    https://www.badcaps.net/forum/showthread.php?t=48765
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Philips 46pfl5505d/f7 dead
    Dunno about any other common issues with these Id say give the diode a shot. If they are in parra just run the set with the shorted one removed set will work but replace all 3 at the same time.
    • ivtec
      • Dec 2008
      • 1967
      Thanks ReeceyBurger123;I'm trying to find ZD 591, PK 5920 the tall Diode but can't find it anywhere,i measured it with diode setting.
      I measured the ZD591 5920 and Positive probe on cathode and negative on anode measures OL and positive on cathode and negative on anode 0.678,
      is this normal? thanks
      • ivtec
        • Dec 2008
        • 1967
        Hi guys which of these To-220 is good for the Replacement of D951,and D950? and how do i connect it to both D950,951? can you make a schematic please, thanks and Happy New Year
        http://www.mouser.com/Semiconductors...x1mj?P=1z0z73r
        • ivtec
          • Dec 2008
          • 1967
          Hi there anybody there? can you please advise
          http://www.mouser.com/Search/Product...4-APT10SCD120K
          • Agent24
            I see dead caps
            • Oct 2007
            • 5095
            • New Zealand
            Did you measure in-circuit or out of circuit? I think ZD591 is in parallel with the other 2 diodes. If you measure in circuit you will get false readings.
            But, zener diodes can't be tested with normal diode test for correct breakdown voltage, only to check if they're not open\shorted anyway.
            As for replacement of the diodes...
            Going from the other thread, the diodes are SB260s. That's 2A at 60v.
            (https://www.badcaps.net/forum/showpo...3&postcount=32)
            A single SB580 as suggested should work. The board looks like it already has a space for a single, larger, DO-201 package diode anyway.
            You could get http://www.digikey.com/product-detai...0CT-ND/3504367
            It doesn't have to be a TO-220 package, although one of those with a heatsink might last longer. I do suspect it's more likely due to variances in forward voltage, one of the original SB260s probably just ended up taking more current and overheating.
            -David VanHorn
            • kew1701
              Philips taw6205 ambilight speaker STM32 mcu dead
              by kew1701
              Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
              04-09-2025, 03:59 AM
              Acer Aspire A515-57-5920 Notebook 5 Specification for Upgrade or Repair
              This specification for the Acer Aspire A515-57-5920 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-57-5920 boardview and A515-57-5920 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-07-2024, 07:20 AM
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • Rubenlily
              Philips 50PUS6503 - dead panel? Picture
              by Rubenlily
              Hey,
              I gave up on my last TV and got a new one to try.
              Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
              Is this fixable in any way or should I just give up on this one too?...
              08-21-2023, 01:07 PM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
