Funai (Emerson) LF501EM4F not turning on
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    #41
    Re: Funai (Emerson) LF501EM4F not turning on
    Originally posted by jayjoesph
    LCD Panel name and #?? Where do i find that.
    On the back of the LCD panel stuck normally on a white label to the metal chassis.
    • jayjoesph
      • Mar 2017
      • 56
      Panel Sticker Number: U3AU1XH
      CN1001 TO LCD PANEL ASSEMBLY Tested with ground to GP001
      1 VLED1=47vdc
      2 ILED1=.006vdc
      3 VLED2=77vdc
      4 ILED2=.074vdc
      5 VLED3=76.5vdc
      6 ILED3=.074vdc
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        #43
        Those readings above would indicate a faulty Vled1 string. I have to be honest but I'm now out of ideas.
        • jayjoesph
          • Mar 2017
          • 56
          Sorry I didnt mention it quick i was taking reading again ABOVE TEST WAS Power board+led forced on
          For some reason PROTECT 3 shows .075 at all spots and drops down to .017 when bl is forced on
          POWER BOARD+LED +MAIN BOARD (NORMAL) TEST NO JUMP NO FORCE ON
          1 VLED1=47vdc
          2 ILED1=.001vdc
          3 VLED2=47vdc
          4 ILED2=3.8vdc
          5 VLED3=47vdc
          6 ILED3=2.5vdc
          POWER BOARD+LED+MAIN (NORMAL HOOKUP+BACKLIGHTS FORCED ON) PROTECT 3=.075 Still
          1 VLED1=47vdc
          2 ILED1=.006vdc
          3 VLED2=77vdc
          4 ILED2=.74vdc
          5 VLED3=76.5vdc
          6 ILED3=.75vdc
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            #45
            I still believe you have a VLed1 problem. As Budm said in an earlier post when the mainboard is not connected the Protect3 is not activating backlight shutdown.
            In Post#35 you said you forced it on and all the leds were working. So you removed the panel and checked the leds visually?
              1 VLED1=47vdc
              2 ILED1=.001vdc
              3 VLED2=47vdc
              4 ILED2=3.8vdc
              5 VLED3=47vdc
              6 ILED3=2.5vdc
              1 VLED1=47vdc
              2 ILED1=.006vdc
              3 VLED2=77vdc
              4 ILED2=.74vdc
              5 VLED3=76.5vdc
              6 ILED3=.75vdc
              If you look at the schematic, the 47VDC reading with all the board connected is correct, that is feeding Voltage to LED Boost Converter circuit.
              when you force on the PS-ON and BL-ON then the boost converter circuit will and give you that 78~82VDC out put. Right now the boost converter for LED1 is not working, per diagram it should be around 82V.
              So it can be that too much load is being seen due to shorted out LED, or LED has open circuit so the Voltage shot up to higher than 82V so it shutdown the boost converter.
              You need to leave the probe on VLED1 and then force on the board to see how high the VLED goes up to.
              "PROTECT 3=.075 Still" that is because there is problem so the line is held LOW.
              BTW:
              i got bored and opened it up all leds came on when forced on
              This cannot be true since 47V IS NOT enough to light up the LED string if that is what you are actually seeing.
              I hope we are not doing goose chase due to wrong DATA and information!
              • jayjoesph
                • Mar 2017
                • 56
                BTW:
                YEs stop the chase . led string is out now opened back up the voltage jumps when connected first moment plugged in to 60vdc very dim for a split second and fades out voltage goes back to 47v So my problem is somewhere in the actual led string ?
                  You can try swapping the suspect bad string to see if it will follow.
                  • jayjoesph
                    • Mar 2017
                    • 56
                    Sure does follow, led string Light fine on other driver
                      I am confused, so you move the string that was dimmy lit to another diver and it lights up fine?
                      • jayjoesph
                        • Mar 2017
                        • 56
                        [/I][/B]
                        YES CORRECT ALL LED LIGHTS ARE FINE. NO LIGHTS UNDER VLED1 when swapped with others. I did unplug the power between swaps
                        It seems something was already bad to flag an error and forcing the unit on killed the issue in that circuit the rest of the way?
                        • jayjoesph
                          • Mar 2017
                          • 56
                          OKay so I followed flow chart no.3 of no picture and tested CN501 Pin 20-23 IF i labled correclty? could not find any mark besides pin one on CN501
                          (Should read 21v for Pin 20-23
                          Pin 23,22 read 21volt
                          Pin 20,21 read 11.8v
                          Pin 8 was checked just to be sure 3volt as it should
                          cathode of D650 read 21volt as it should
                          • jayjoesph
                            • Mar 2017
                            • 56
                            not sure if i guessed the pinout correctly. I searched all over for some sort of key in the schematic. the last 4 do read 21v if it was counting up and down rather then straight across. still out light from led 1 just low voltage at what ever strip its hooked to . no wire fault
                            • jayjoesph
                              • Mar 2017
                              • 56
                              ALright i did some poking around before I put it to the side for a bit. Q1102 may be toast? It does not test the same as Q1202,Q1302(tested exact same) shouldn't they read the same on tester or volt meter being the 3 circuits are identical test were done off
                              voltage at source pins of those 3. Q1202+Q1302 start at about 10.5 drop to 9.5 quickly.. Gate Q1102 Starts 11.5 then drops to .006 after a few moments
                              what is acceptable replacement few part board still to look at but i have a few no match yet ?
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                #55
                                You can check the mosfet. There are plenty of Youtube videos on how to test. If it tests OK then there may be a drive problem with IC1101
                                • jayjoesph
                                  • Mar 2017
                                  • 56
                                  it checked bad these schematics are difficult somewhat...is there parts i can use to bypass or 2 to use maybe i can find easier? Other than order or find another of same model? either to verify rest of set is working correct
                                    If I were you I would remove R1108 (1K) connected to pin 7 (ERROR) OF of IC1101 which is the LED driver for the VLED1, this will stop the VLED1 circuit from pulling PROTECT3 low. You will now have only two sets of LEDS working and the TV should function unless it has more than one problem.
                                    • jayjoesph
                                      • Mar 2017
                                      • 56
                                      worth a shot.. removed it plugged in main board and full power at rails did not push power no black lights so jumped all besides ps-on protect 3 =.5v
                                      • jayjoesph
                                        • Mar 2017
                                        • 56
                                        i think its bout time to give up lol. Was hoping to purchase the main board if anything
                                          One of the three IC is pulling down that PROTECT3, the output n pin 7 is Open Drain output so all three error lines are connected as an OR set up, there is resistor at pin 7 of each IC, you might as well remove them all to see if PROTECT 3 will go HIGH.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
