V315B1-C01 TCON - AS15F Swap out - resistor values
  • pic_whiz
    • Feb 2014
    • 36
    • United Kingdom
    Hi All,
    I was just in the process of replacing the usual failed AS15F Gamma IC but inadvertently removed 8 of the SMD resistors that connect to the IC!
    The values of each resistor I have are:-
    6K
    1.3k
    752r
    752r
    430r
    388r
    160r
    140r
    Would someone be so helpful as to identify which resistor goes into which position on the attached photo marked 1-8 (If only I had a spare board to compare :-)
    Cheers,
    Matt
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: V315B1-C01 TCON - AS15F Swap out - resistor values
    It's hard work but if you can read it from the data sheet, google AS15F data sheet
    • pic_whiz
      • Feb 2014
      • 36
      • United Kingdom
      Thanks Dick. I've already looked at all possible datasheets/diagrams but unable to find the same values located on any of them.
      Still hoping someone may have the same board to do a quick meter reading of their resistors.
      Cheers,
      Matt
      • pic_whiz
        • Feb 2014
        • 36
        • United Kingdom
        Any more help guys? Still struggling to find the info..
        cheers,
        Matt
        • vinceroger69
          • Mar 2012
          • 6714
          ignore wrong thread sorry
          • pic_whiz
            • Feb 2014
            • 36
            • United Kingdom
            bump!
            • pic_whiz
              • Feb 2014
              • 36
              • United Kingdom
              • Charudatta
                • May 2017
                • 3
                • India
                Does any one have standby V315B01-C08 T-Con board . I need resistor values for 1-18 as in Picture. Some resistor are swiped by heatgun bi mistaken. IC chip is As15-HG NOT AS15- F. I have datasheet for AS15-HG but is it worth. Not clear from application data. Any on could help me please
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  I realize this is older post but may help someone with the V315B1-C01 per post 1
                  1=160r
                  2=6k
                  3=140r
                  4=388r
                  5=1.3k
                  6=430r
                  7=752r
                  8=752r
