My LG PLasma lower y-Buffer went out again? why
  • t333
    • 20
    • US
    Hi All
    hoping i can get some idea with what is wrong with my LG plasma 50PA6500. worked fine for 2 years with no issues then last month i turned it on and got sound but no picture,
    searched online i found out its the Y-Sustain board that could be bad, ordered a new one and replaced it but still same issue,so it was not the Y-sustain board, then i checked both y-buffer boards and lower one was the culprit there was one short IC in lower y-buffer board as i checked with an old analogue multi meter, Ordered a new lower y-buffer board and after i replaced the lower Y-buffer board i got a picture on the Display, but next day i turn it on and there was no picture again, just sound, it was the lower y-buffer board that went out again.
    What is causing the y-buffer board to go out even with a new Y-sustain board? do i need to order and replace both top and lower y-buffer boards or something is wrong with the power supply/Z-boards? can any one help me to identify the problem??
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: My LG PLasma lower y-Buffer went out again? why
    Could be bad panel ribbons on this model. Im aware the panel ribbons have a habbit of shorting on these and killing the buffer. Could also be bad Zbias cause by cold solder joints on Zsus.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      I agree. Check the solder joints under the copper coils on the board. Check every solder joint under there. Fresh lead solder never hurts.
      • t333
        • 20
        • US
        Hi reeceyburger and tvtimmy thank you for your response, can u tell me what exactly I need to look for?
        another question: my z-sustain/logic and power boards are not bad, correct?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          More likely a bad panel if the Same Chip went....
          TELEFIX
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Cooperr
            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
            by Cooperr
            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
            10-21-2025, 01:11 PM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
