Panasonic TX-P42ST31B 7blinks
  • sienoki
    sienoki
    • Jan 2012
    • 314
    Thought id try n fix this set for a friend..common 6 IGBTs blown..bought the repair kit and also replaced IC501/IC502..Q531/501
    So its an TNPA5330 SN board and after replacing the parts still 7 blinks..the 2 fets and fuse has also failed on the PSU..ive ordered them so im going to get PSU back to life before going any further with SN board..after reading all the posts on here regarding TNPA5330 thought id double check my soldering Q401-30F131 wasnt soldered correctly with the tab.
    So my question is how do i test the SN for shorts..thx
  • sienoki
    sienoki
    • Jan 2012
    • 314
    Re: Panasonic TX-P42ST31B 7blinks
    Ground lug on Sn board to white connector gives constant beep on 1 leg and OL on the other leg and thats the same with tv chassis being the ground..so the SN board is still shorted right?
    • flocko
      • Nov 2012
      • 1121
      • uk
      Please use the search engine for all you need to know about testing and repairing these and other Panasonic board.There are pages and pages of info on here, that I and others have posted in the past . So please help yourself
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        what about across just the two pins of the connector
        http://alpengeist-tvrepair.blogspot....330-board.html
        • sienoki
          sienoki
          • Jan 2012
          • 314
          480 1 way n OL the other in diode mode
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            With a DMM and diode mode. Ive also had a Xcap on the input of this board short out as well after the 30f131 fets failed. 1.5uf 250v red colour near Vs input connector.
            • sienoki
              sienoki
              • Jan 2012
              • 314
              Thx vinceroger69..ive replaced all them parts from that blog except Q451..neg probe on collector n pos probe on gate i get OL so part failed also?
              Should i pull that out of circuit n see if short gone..thx
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                ive no idea too be honest never repaired one of these boards myself but read a few threads about the repair of them not sure if that blog site lists all the faulty parts either but in the comments he has good reviews.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  To test the buffer boards on TNPA5330 you need to test in diode mode.
                  Black prope on "TPVFG" and red prope on the connectors.
                  Measuring for short on the white prong connector will beep shortly in 1 way and won't beep the other way if the board is "ok".
                  If you have bad/fake parts the board will measure ok but still can blow when power is injected.
                  You need to fix the power supply first and measure the voltages WITHOUT the SC board. I used R6020ANX for the PS.
                  It must measure 107V on start up ( blinking led ) and then jump to 215V before shutting down to 7 blinks. ( Because there is no y-sus ).
                  • sienoki
                    sienoki
                    • Jan 2012
                    • 314
                    Ive pulled the Q451-DG302 out n it reads OL on both legs with neg probe on tab?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Ps TPVFG is on the top left corner of the y-sus board.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        DG302 is probably not shorted. If there is not worked on before only the 6 IGBT's + IC501 etc are shorted.
                        Black prope on tab and red on left or right leg , no beep is ok.
                        • sienoki
                          sienoki
                          • Jan 2012
                          • 314
                          I get a 5sec beep then 481 n 1sec beep then OL
                          IVE ordered R6015ANX for PSU are they ok?
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            TPVFG bottom left black probe on test point n ran red along all buffer connectors n no beeps so they be ok
                            • sienoki
                              sienoki
                              • Jan 2012
                              • 314
                              No beep on either leg of DG302 so thats safe to solder back on?..just need to buy some heatsink glue when repaired hopefully
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                You mean top left TPVFG ( Between 2 buffers ). Yes , no beeps is ok.
                                Both sides beep is not good. Check if Q661 bottom left corner is not shorted.
                                Q441 / Q 451 are both ok? Check for short between 2 outer legs and tab + 2 legs.
                                Did you use a repair kit? If so , which one? There are a lot of fakes on eBay.
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  Yes that DG302 will be fine. Im sure only the 6 known IGBT's have failed.
                                  On this board originally q401 , q402 , q403 , q421 , q422 , q423 , IC502 & Q531 will fail.
                                  If the buffers are failing the top side igbt's will read short including all diodes and DAF30A. Removing all the shorted igbt's will result in all diodes still ok so there is no need replacing them all.
                                  Just wait for the PS parts to arrive or get a replacement Ps.
                                  • sienoki
                                    sienoki
                                    • Jan 2012
                                    • 314
                                    Q661 n Q441 ok cant find Q451 as yet doh..my bad the 1 under heatsink..yeah no beeps
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      componentalliance for 6 main IGBTs n MBTV electronics for RF1501/DAF30A..SMD transistors from M-core..n ics from chipbay_store..went with cheaper option at 1st with just the 6 IGBTs n really i should have just bought afull kit from 1 supplier cos it aint worked out cheap doh
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        I hope you will receive good items. The 30F131 and RJP30H2A are almost all fake.
                                        If you can wash off the logo + name with alcohol/aceton or its fading out then you probably have fakes.
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • Mnawar27
                                          Panasonic CF-H2AU24EF3 bios locked
                                          by Mnawar27
                                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                          I need help to remove it,
                                          thankyou all.
                                          SN; 2FKCA26876...
                                          11-16-2024, 08:00 AM
                                        • Yanleb
                                          Panasonic part number in service manuals
                                          by Yanleb
                                          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                          For an example, look at the attached PDF.
                                          Do you have a way to cross reference the Panasonic part number with the actual part number?
                                          Thanks....
                                          07-03-2023, 08:16 PM
