I'm working on this cheapo Magnavox LCD, and I was wondering if anybody had any troubleshooting pointers. What happens is that when anyone tries to turn it on, the red light blinks, the screen turns on, and the splash screen appears, but then it turns off. Nothing looks obviously bad on the power supply board or mainboard. Any ideas?
Magnavox 46ME313V/F7 LCD shuts off immediately after displaying splash screen
Tags: None
Re: Magnavox 46ME313V/F7 LCD shuts off immediately after displaying splash screen
I had the exact same problem with an 50" emerson that uses same pcb board (BA4GU5G0201 3), after trying power board from another set, and disassembling the screen to check for bad leds I took a chance and ordered in a mainboard from a 40" magnavox that looked the same and had the same pcb model number, same plugs, etc just different part number on the stickers for 20$ on ebay(the right board was 70$ which was more than i was willing to spend) and other than needing a magnavox remote control now it worked great. So I'd say your problem is mainboard also. -
The quest for cheaper repairs
I had the exact same problem with an 50" emerson that uses same pcb board (BA4GU5G0201 3), after trying power board from another set, and disassembling the screen to check for bad leds I took a chance and ordered in a mainboard from a 40" magnavox that looked the same and had the same pcb model number, same plugs, etc just different part number on the stickers for 20$ on ebay(the right board was 70$ which was more than i was willing to spend) and other than needing a magnavox remote control now it worked great. So I'd say your problem is mainboard also.Comment
you would be better seeing what is putting it into protection and shutting it down .
it could be almost anything if indeed is protecting itself .might just be a bad solder joint maybe not . few voltage checks should get you on the way if you are up for that sort of thing ?
most likely a capacitor not charging fast enough because its no longer good .
voltage checks should be a big help . no use guessing unless its a well proven fault with a certain boardLast edited by petehall347; 01-11-2017, 06:47 PM.Comment
just a little progress...
After finally getting a working board, I'm having slightly better luck with this thing, but not much. It now boots past the splash screen and shows the channel number in the corner, but then immediately shuts off after that.
I get a fairly low-res Emerson emblem followed by the channel number in the corner before it calls things quits. Any ideas as to what else might be ailing this sorry thing?Comment
Still nothing
Any new ideas? Could a power supply or bad lamps be causing this kind of failure? Or is it possible that I ended up with another bad mainboard?Comment
Try something new!
I guess I'll try looking for a power supply and see if it works any better with that.Comment
Check the DC voltage....I suspect a Backlight fault, thoughComment
Check the DCV on those jumpers when TV is OFF, black probe on chassis and leave the red probe on one of the jumper and turn on the TV and see what you get then wait a few seconds to see if reading changes, do the same for another PROTECT jumper.Never stop learning
Results!
PROTECT3 measures .1volt while it is booting up and displaying the splash screen, then jumps to .5volt (or so) for a fraction of a second as it shuts off. After the television shuts off, PROTECT3 drops to zero.
PROTECT1 registers absolutely nothing at any time.
Is that normal behavior?
Is there any easy way to test for that short of dismantling the entire panel?Comment
best way forward?
If it makes any difference, I tested this with the backlights disconnected and got the same symptoms, (sans backlights, of course) if that makes any difference.
Based on these findings and the aforementioned measurements, what would be the best way forward with this? Just dive in and check the backlights?Comment
if you want you can connect the back lights to the PSU, fire the PSU up and measure the DC voltage of each back light string. Other than that, you are on the correct way to check the back lights.Comment
Tested lamps.
Well, I finally broke down and tore this thing apart. Turns out that there is some kind of issue with backlights not lighting up. The weird thing, however, is that after testing each lamp in the middle row individually with the multimeter, I found that they all light up and work. Does this mean that I've got a bad power supply?Comment
No voltage at middle string
Now we might be on to something. The first string measured 47-52 volts, the third string measured within a couple volts of that, but the middle string measured pretty much nothing. What could this mean?Comment
On this TV PSU, each string has its own control ic, etc. IC1301, IC1201 and IC1101. Each has its own circuitry to control one string each. Now you have to find out which circuit isn't working. I am guessing the one with IC1201 since it is the middle one, but you have to verify that.
What part numbers does IC1201, Q1201 and Q1202 have? Check D1202 Q1201 and Q1202 for a short.Comment
by tonybig10Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...-
Channel: Schematics and Boardviews
03-07-2025, 01:03 PM -
by huzoThe model is 15ec-1061nm
Board number is DAG3EDMB8D0​
SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...10-29-2024, 12:05 AM -
by brav1ezHello everyone,
I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
I’ve tried:
- CMOS reset
- Removing the SSD/HDD
- Reseating RAM (removing each stick individually stops boot completely)
- Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
With...09-07-2025, 10:47 AM -
by chaos-theoryI have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and... -
by baglaivladHello everybody!
Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...11-20-2024, 08:14 AM - Loading...
