Magnavox 46ME313V/F7 LCD shuts off immediately after displaying splash screen
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    I'm working on this cheapo Magnavox LCD, and I was wondering if anybody had any troubleshooting pointers. What happens is that when anyone tries to turn it on, the red light blinks, the screen turns on, and the splash screen appears, but then it turns off. Nothing looks obviously bad on the power supply board or mainboard. Any ideas?
  • cyricdark
    • Nov 2012
    Re: Magnavox 46ME313V/F7 LCD shuts off immediately after displaying splash screen
    I had the exact same problem with an 50" emerson that uses same pcb board (BA4GU5G0201 3), after trying power board from another set, and disassembling the screen to check for bad leds I took a chance and ordered in a mainboard from a 40" magnavox that looked the same and had the same pcb model number, same plugs, etc just different part number on the stickers for 20$ on ebay(the right board was 70$ which was more than i was willing to spend) and other than needing a magnavox remote control now it worked great. So I'd say your problem is mainboard also.
    • SurrealMustard
      • Jan 2015
      • 486
      The quest for cheaper repairs
      Thanks for following up. That's what I ended up assuming based on the symptoms and the vast presence of mainboard repair kits on eBay. Against my better judgement, I sprung for the overpriced $70 board online and it was totally dead. Are there any of those $20 units left that you found?
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        you would be better seeing what is putting it into protection and shutting it down .
        it could be almost anything if indeed is protecting itself .might just be a bad solder joint maybe not . few voltage checks should get you on the way if you are up for that sort of thing ?
        most likely a capacitor not charging fast enough because its no longer good .
        voltage checks should be a big help . no use guessing unless its a well proven fault with a certain board
        • SurrealMustard
          • Jan 2015
          • 486
          just a little progress...
          After finally getting a working board, I'm having slightly better luck with this thing, but not much. It now boots past the splash screen and shows the channel number in the corner, but then immediately shuts off after that.
          I get a fairly low-res Emerson emblem followed by the channel number in the corner before it calls things quits. Any ideas as to what else might be ailing this sorry thing?
          • SurrealMustard
            • Jan 2015
            • 486
            Still nothing
            Any new ideas? Could a power supply or bad lamps be causing this kind of failure? Or is it possible that I ended up with another bad mainboard?
            • CapLeaker
              Leaking Member
              • 8158
              Check the protect jumpers on the PSU working vs after shut down.
              • SurrealMustard
                • Jan 2015
                • 486
                Looking for protection jumpers
                Where would those be located?
                • SurrealMustard
                  • Jan 2015
                  • 486
                  Try something new!
                  I guess I'll try looking for a power supply and see if it works any better with that.
                    Re: Looking for protection jumpers
                    PROTECT1, PROTECT2... printed right next to the jumpers on that power supply board.
                    • SurrealMustard
                      • Jan 2015
                      • 486
                      Found!
                      Ah, I found one of them. What exactly am I looking for on it?
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        Check the DC voltage....I suspect a Backlight fault, though
                          Check the DCV on those jumpers when TV is OFF, black probe on chassis and leave the red probe on one of the jumper and turn on the TV and see what you get then wait a few seconds to see if reading changes, do the same for another PROTECT jumper.
                          • SurrealMustard
                            • Jan 2015
                            • 486
                            Results!
                            PROTECT3 measures .4volt after the power button is pressed before it starts booting up.
                            PROTECT3 measures .1volt while it is booting up and displaying the splash screen, then jumps to .5volt (or so) for a fraction of a second as it shuts off. After the television shuts off, PROTECT3 drops to zero.
                            PROTECT1 registers absolutely nothing at any time.
                            Is that normal behavior?
                            Is there any easy way to test for that short of dismantling the entire panel?
                            • SurrealMustard
                              • Jan 2015
                              • 486
                              best way forward?
                              If it makes any difference, I tested this with the backlights disconnected and got the same symptoms, (sans backlights, of course) if that makes any difference.
                              Based on these findings and the aforementioned measurements, what would be the best way forward with this? Just dive in and check the backlights?
                              • CapLeaker
                                Leaking Member
                                • 8158
                                if you want you can connect the back lights to the PSU, fire the PSU up and measure the DC voltage of each back light string. Other than that, you are on the correct way to check the back lights.
                                • SurrealMustard
                                  • Jan 2015
                                  • 486
                                  Tested lamps.
                                  Well, I finally broke down and tore this thing apart. Turns out that there is some kind of issue with backlights not lighting up. The weird thing, however, is that after testing each lamp in the middle row individually with the multimeter, I found that they all light up and work. Does this mean that I've got a bad power supply?
                                  • CapLeaker
                                    Leaking Member
                                    • 8158
                                    again, fire the PSU up and measure the DC voltage of each back light string on the connector at the PSU with the LED's connected.
                                    • SurrealMustard
                                      • Jan 2015
                                      • 486
                                      No voltage at middle string
                                      Now we might be on to something. The first string measured 47-52 volts, the third string measured within a couple volts of that, but the middle string measured pretty much nothing. What could this mean?
                                      • CapLeaker
                                        Leaking Member
                                        • 8158
                                        On this TV PSU, each string has its own control ic, etc. IC1301, IC1201 and IC1101. Each has its own circuitry to control one string each. Now you have to find out which circuit isn't working. I am guessing the one with IC1201 since it is the middle one, but you have to verify that.
                                        What part numbers does IC1201, Q1201 and Q1202 have? Check D1202 Q1201 and Q1202 for a short.
                                        • tonybig10
                                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                          by tonybig10
                                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                          03-07-2025, 01:03 PM
                                        • huzo
                                          HP Omen shuts down when loading OS
                                          by huzo
                                          The model is 15ec-1061nm
                                          Board number is DAG3EDMB8D0​
                                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                          10-29-2024, 12:05 AM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • baglaivlad
                                          A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                                          by baglaivlad
                                          Hello everybody!
                                          Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                                          After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                                          11-20-2024, 08:14 AM
                                        • samuelphirik
                                          Dell inspiron 15 7567 sudden shuts down
                                          by samuelphirik
                                          Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                                          During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                                          I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                                          Now I've noticed that laptop...
                                          07-02-2023, 05:45 AM
