42PT350R nedd help isolating the problem
  • buchman
    • Aug 2015
    • 294
    • greece
    Hi guys,
    My T.V. has a clicking noise when I turn it on, but have no picture or sound.
    I have tested the VS and VA voltages and while all boards are connected, I don't get the correct measurement as stated on the back of the T.V.
    When I unplug all ribbons and boards only then I get the correct voltages on the PSU.
    I have cheked all the capacitors and they seem to be O.K (including the ESR).
    How do I pinpoint the bad board?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 42PT350R nedd help isolating the problem
    Use the search feature on the forum to help you find out how to diagnose shorted sustain board. As Psu voltages rise with them disconnected Psu is ok.
    • buchman
      • Aug 2015
      • 294
      • greece
      Thanks for your comment.
      Unfortunately I couldn't find anything about how to diagnose shorted sustain board except of one thread that isn't help me much.
      What should I wright in the search box?
      Sorry and, thanks for the understanding.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        https://www.badcaps.net/forum/search...archid=7762376
        • buchman
          • Aug 2015
          • 294
          • greece
          Thank you very much ReecyBurger123
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Any luck matey ?
            • buchman
              • Aug 2015
              • 294
              • greece
              Not yet unfortunately. I did found one thread that looks like the guy has the same problem like I do.
              A few hours later suddenly the link that you have provided stopped working.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Hmm the search feature on here has become useless as or recent. Right have you a DMM ?
                • buchman
                  • Aug 2015
                  • 294
                  • greece
                  Yes I have. Plus, I have ESR meter too.
                  • bikerbuddy
                    • Jun 2011
                    • 134
                    https://www.badcaps.net/forum/showth...ht=LG+42PT350R
                    Found this see if it will help .
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • Zeonalbasta
                      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                      by Zeonalbasta
                      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                      09-13-2024, 01:17 PM
                    • Gibon378
                      Problem with stopping audio and video for no reason
                      by Gibon378
                      PC Specs:
                      • CPU: Ryzen 5 1600
                      • GPU: GTX 1080 Palit JetStream
                      • MOBO: ASRock ab350 PRO4
                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                      • PSU: XFX 650W (don't remember what model)
                      • OS SSD: ADATA SP920
                      • OS: Windows 10 21H2
                      Problem description:
                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                      11-19-2022, 09:41 AM
                    • perzyk23
                      Lenovo T580 - LCD Panel problem - error 0288
                      by perzyk23
                      Good morning,
                      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                      10-25-2024, 12:42 AM
                    • lazaro.089
                      Asus Zephyrus M16 / GU603ZW problem
                      by lazaro.089
                      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                      CPU: Core i9-12900H
                      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                      08-26-2025, 06:33 PM
