I have a 60PA5500 with no VSC or VY voltage. Va is steady at 55V, Vs is a good 205V, and Vzb is a steady 120V. But I get nothing at VSC (should be 150V), and a fluctuating 7 to 24V at VY (should be -190). I've replaced the VSUS board with no success, and just recently replaced most of the semiconductors on the board - same result. I have good Va and Vs voltages going to the YSUS board, and the YSYS board hums (heat-sinks get barely warm), but no voltage at VSC or VY. Both fuses are good. Both upper and lower buffer boards have been replaced, with the same result. Any ideas?
LG 60PA5500 No VSC or VY Voltage
Tags: None
Re: LG 60PA5500 No VSC or VY Voltage
1. Measure the M5V and see if it is remaining low...If it is then you have a Main Bd problem.
2. See if you are getting 15V from Y-SUS Bd to the X-PWB.
3. Check if you have 5V and 17V to the Control Bd.
4. Look for presence of 3.3V from Control Bd to the X-PWB.
5. VSC and -Vy voltages are generated in the Y-SUS Bd. -
Steady 5V and M5V on the power supply board, ZSUS and YSUS.
Which is the X-PWB?
I have steady 5V at positions 4-6 at connector P105 on the Control Board. I have 17V from the power supply to the main board, as well as 5.2V. Where should the 17V be present on the control board?
Where on the Control Board?Comment
1. M5V is OK.
2. X-PWB are the long boards at the bottom of the TX near the speakers.
3. 5V and 17V should be on one of the pins on the Control Bd jacks.
4. 3.3V should be on one of the pins on the Control Bd jacks to the X-PWB.Comment
I have 3.3V at the first pin of all three connectors (P102, P102, P104) on the ribbon connectors that go to the X boards at the bottom. Also, Va (55V) on the two-wire black-and-white jumpers from the YSUS board and the X boards.
I have 16.2V at pins 1 and 2 (marked DD) at connector P105 (the ribbon cable that goes to the YSUS board), and 5V at pins 2, 3, and 4.
VY (on the YSUS board) jumps between about 8V and 24V, about every half-second. VSC varies between about 1.2V and 9V - the higher voltage increasing to 9V and decreasing to about 2V, then climbing again, every 20 seconds or so.Comment
Remove all buffers and retest Vsc.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Thanks for your input. With both buffer boards disconnected, VY is now 185V (spec), but VSC is a steady zero.Comment
Buffer is failed replace it. Also resolder Erc coils on Xsus.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I also suggest adding a fan to the Cpu heatsink and reapplying its thermal paste with thermal silicon help keep that from failing junk Tv's these are.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Both buffers have been replaced. That's not to say I didn't get faulty boards, but. . . Also, if the VSC voltage is generated on the YSUS board, how would replacing the buffers make it generate a voltage? Also, are you talking about the CPU(s) on the control and main boards? Right now, there are no heat sinks in place.Comment
If Vsc was failed with the buffer in but working with no buffer it means the buffer is short and loading it down so the smp is shutting down Vsc. Also yes heatsinks on the mainboard and control board.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
VSC was NOT present with the buffers removed. VSC voltage was zero with the buffers removed.Comment
After taking a break from this, I'm ready to try again. I've had the YSUS board checked, and found no problems. Here is a little more information. With the buffer boards disconnected, I do get a good VY voltage (185V), but with the leads +to+ and -to-, it gives a positive voltage. The tag says VY should be -185V. Also, Vsc in still nonresistant. One other thing. I've never had any sound on this - no static, no hum, nothing. With no video I can't change the inputs to even see if it's getting a signal to produce audio, but, nothing. Could the main board, that houses the audio, be causing my no Vsc voltage problem as well?Comment
Vsc is Vy on Lgs my bad. Also buffer is failed in your case replace it.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Don't mean to cause problems, but Vsc is not VY on an LG. I'm no technician, but the label shows readings for both Vsc (150) and VY (-185). In addition, there are two test points on the YSUS board, clearly marked VSC and VY.
Buffers have been replaced (and checked). With the buffers removed, still no Vsc.Comment
Check the components on both sides of the board around the transformers. There are also fuses on the board fs202 is one I can see but there are probably more.Last edited by dick_barton; 03-15-2017, 09:56 AM.Willing to help but I'm no expert.Comment
Surely its a Y board problem as the scan voltage is produced from the Vs. So yes check all components back from Vsc test point.Comment
Assuming...7 Photos -
by LorettoHi all,
this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,... -
by LorettoHi all,
by PlasMattI have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?... - Loading...
