LG 60PA5500 No VSC or VY Voltage
  • abbottdave
    • Apr 2016
    • 41
    Re: LG 60PA5500 No VSC or VY Voltage
    Thanks, I'll do a little more checking.
    • freakaftr8
      • Oct 2012
      • 3743
      Try installing just the lower buffer board leaving the upper buffer board disconnected and see if you have VSC. This model TV is plagued with the plastic bezel surround eating through the top scan ribbon cable on the panel. Intern this loads down in shorts out the very top IC on the upper buffer board
      • abbottdave
        • Apr 2016
        • 41
        Any idea why I have no sound as well?
        • freakaftr8
          • Oct 2012
          • 3743
          I believe this model shuts off from lack of current draw through power supply if neither buffer board is connected
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • Loretto
            Samsung SMPS BN44-00339A
            by Loretto
            this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
            I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
            I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
            I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
            03-29-2025, 08:30 AM
          • Loretto
            by Loretto
            03-28-2025, 10:28 AM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
