Toshiba regza 52" sound no picture
  • Dan Surra
    • Dec 2016
    • 36
    Re: Toshiba regza 52" sound no picture
    It clicks when you turn it on and off. Yellow light flashes during initial power up and then a steady green light is on at base of TV. That is basically the same as it was when it was working, Packard
    • Dan Surra
      • Dec 2016
      • 36
      Originally posted by budm
      Service manual.
      Check those Voltages when TV is off and when the power switch is activated.
      Thanks, Bud this is very helpful
      • Dan Surra
        • Dec 2016
        • 36
        Ok, I did the diagnostic work recommended. All 5 Inverter supply pins read a healthy 24.3 volts. These would be at P861 and P860. The next step in the flow chart is pins 1 and 2 @ P810A. They read the recommended 12 volts (12.3 actual). Flow chart says if this is the case to try one or both of the CCF inverters. If that does not help replace the LCD display.
        I don't even know what or where the inverters are. Any suggestions as to how to proceed? Will post close up pics of boards in next post. Thanks in advance. Dan
        • Dan Surra
          • Dec 2016
          • 36
          • vinceroger69
            • Mar 2012
            • 6714
            in post 12 on the left and right hand of the tv you can see the invertor transformers (6 on each side) on pcbs is there a number printed on them? these boards also sometimes have fuses on them so worth checking there ok.
            • Diah
              • Feb 2013
              • 6439
              sorry to all who post answer here .. OP rubbished your TV and got other.. the repair coast will be round half price if you got other TV in case you succeed ... look all run away to guide you. except vinceroger69
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                #27
                If only you would run away,sigh
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                  So you have 24V supply for the inverter board, but do you have BL-ON to turn on the inverter board.
                  See page 3 of the PDF, look at CN61 pin 1 for the BL-ON signal ,and other Voltages as well on that connector.
                  • Dan Surra
                    • Dec 2016
                    • 36
                    transformer #'s are 0095AD U00815 CY on left side looking from rear and 0095AD U00818 CY on right.
                    if fuses are labeled F400 and F401 on board, they are good.
                    • Dan Surra
                      • Dec 2016
                      • 36
                      Diah, what do you mean OP rubbished my TV? What is OP? Please explain. Finally, I really do appreciate all the helpful insight from others on this post. Thanks.
                      • Dan Surra
                        • Dec 2016
                        • 36
                        Well, that is the next step I guess. I may not be able to get at this for a day or so. Be patient with me and again, Bud, thank you for your advice. Dan
                        • Dan Surra
                          • Dec 2016
                          • 36
                          OK, was able to get some readings on the BL-ON CN61 connector today. They are as follows, pin 1 BL ON actual 3.26v (listed to be 5v), pin 2 empty, pin 3 empty, pin 4 VBR actual 3.28v (0-3.3v listed), pin 5 BL Det actual 3.25 (none listed), pin 6 continuity to ground, pin 7 empty. These were taken with the unit turned on.
                          Thanks in advance.
                            BL-ON of 3.26VDC is fine I would think anything over 2.5Vdc will be = ON.
                            VBR (DIM) is also fine.
                            BTW, do you see any blinking LED ERROR codes? Look at the PDF for error codes listing.
                            • Dan Surra
                              • Dec 2016
                              • 36
                              It blinks three times, twice (yellow) when first powering up and then goes to a solid green. I believe it always did this when turning the set on. Hope this helps, Bud. You've been a great help Bud. Any suggestions as to what else I can check?
                              • Dan Surra
                                • Dec 2016
                                • 36
                                Ok, I have 24v at all inverter board terminals and 3.26v at BL-ON terminal. Where do I go from here? From standpoint of a novice, I have received some great advice on here. Hope we can figure out what is causing sound and no pic issue. I hate to trash the unit.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  i wonder if it could be a faulty inverter transformer it only takes one to be bad maybe budm has a idea if this could cause the issues your having as you do seem to have all the correct voltages.
                                  • Dan Surra
                                    • Dec 2016
                                    • 36
                                    I have NO clue vinceroger, LOL. Is there a board that we could try and replace that doesn't cost more than the unit is worth?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      i would wait for budms input etc as it uses ccfl tubes maybe one has gone faulty i would expect the screen to flash quick though with the 2 seconds to black fault have you tried in a really dark room and powering up the tv do you get any flash on the screen?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        budm had two really good threads but i dont know if these tests will work on your boards as im not sure if invertor ccfl fault any your set has invertors on the left and right of the set so not sure how to carry out the tests im sure budm will advise.
                                        https://www.badcaps.net/forum/showth...x+dx-40l261a12
                                        https://www.badcaps.net/forum/showth...er+testing+cfl
                                          Since you do have all the required Voltages and the command signal (it is still questionas to if the BL-ON should really be truly 5VDC or not), and Vince suggested, I would look at the TV in really dark room to see if the backlights even flash on for second or not.
                                          Bad lamp/lamps/transformer will not stop the inverter circuit to fire up the lamps to start first, if it detects the problem int he first 3 seconds then the circuit will go into protection shutdown.
                                          • jord4231
                                            Toshiba 37AV500A Regza TV good power supply no sound no picture
                                            by jord4231
                                            Hi Everyone,
                                            I'm working on a Toshiba 37AV500A Regza TV.
                                            The issue:
                                            TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                            The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                            I checked the PSU voltages and everything looked good.
                                            No bulging caps or signs of heat.
                                            24v aud = 24.41v
                                            12v = 11.98v
                                            5v = 5.062
                                            p_o/f = Goes high...
                                            03-29-2022, 09:21 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
