Baird JO47BAIRD Main Board problem
  • jczarniak
    • Oct 2015
    • 179
    Got another one Baird 47" with same problem.
    Standby light ON (still), TV not switching on, no reaction on remote / side buttons.
    Power supply looks alright, must be the main board.
    Main board CV109H V1.2
    Anyone had a similar problem?
    Is there any way to fix the main board?
    Thank you for support.
  • Hamie
    • Apr 2014
    • 1383
    Re: Baird JO47BAIRD Main Board problem
    When you say power supply looks OK?
    Is it OK? Have you checked the output voltages?
    • jczarniak
      • Oct 2015
      • 179
      Yes, I did.
      Voltages looks alright.
      • Hamie
        • Apr 2014
        • 1383
        Still got standby light?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Looks as though this set may have problems with EEPROM corruption
          http://www.tv.quuq.org/forum/index.p...29235#msg29235
          http://www.ohmsupplies.co.uk/epages/...s/E2P066-CP098
          • Hamie
            • Apr 2014
            • 1383
            Sorry reread the op.
            My thoughts would be eeprom.
            • vinceroger69
              • Mar 2012
              • 6714
              does this set use one or two psu s im sure i have worked on one and it had two psu s in it.
              Edit it was a Baird X47DTV i worked on so diffrent set
              as above my guess mainboard issue so if a eeprom is cheap enough certainly worth a try if not look on ebay for a mainboard as long as it matches your panel you should be fine as i some times find replacement boards are cheaper than a new programmed eeprom (you can always take a copy of the working eeprom and maybe try re programming your old board and have a spare)
              • jczarniak
                • Oct 2015
                • 179
                That makes sense.
                Thank you.
                • jczarniak
                  • Oct 2015
                  • 179
                  One power supply in this set.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Yes sorry i edited my above post i just looked at my notes i made and was a diffrent model number.
                    • jczarniak
                      • Oct 2015
                      • 179
                      Standby light is on, that's correct.
                      • jczarniak
                        • Oct 2015
                        • 179
                        No problem.
                        Thank you.
                        • jczarniak
                          • Oct 2015
                          • 179
                          TV back in action after replacing the main board.
                          Second hand main board on eBay was cheaper then eeprom.
                          Thank you for your support guys.
                          Regards.
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
                          • JDC
                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                            by JDC
                            ONN 100012588
                            Issue: No Power, Then Rebooting After Main Board Change
                            Short answer: replace main board and power board
                            Technical answer: replace main board and Q306 & Q307 on power board.
                            Long answer:
                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                            07-15-2022, 07:39 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
