KDL-55hx800 has 6 blink code
  • nwcs
    • Dec 2015
    • 311
    • usa
    This set will run for about 5 minutes then shut off and the standby light blinks 6 times then repeats. I can press the power button and it comes back on but for a shorter time. I have the service manual and in the flow chart I am supposed to check the voltage at JL2565 to determine if the bal board or tcon failed. Does anyone know where JL2565 is located since I have looked and can not find it.
    Re: KDL-55hx800 has 6 blink code
    How about uploading the service manual you have? or the link to it?
    • nwcs
      • Dec 2015
      • 311
      • usa
      I will in the morning when I get back into the store.
        Per service manual I found, 6-blink = Backlights Error, page 9.
        • nwcs
          • Dec 2015
          • 311
          • usa
          I see it is a backlight error but according to the service manual I need to check the voltage at JL2565 and I just can not find that. I am pretty sure all of the led's are good since it does work for 5 minutes but without checking for 2.65V at JL2565 I can not isolate which board it might be. Anyway I have attached the service manual and page 29 is where it looks for the 2.65V.
          • nwcs
            • Dec 2015
            • 311
            • usa
            I am back trying to fix this tv and need some suggestions/help. I have checked the voltages on cn6753, 12v reads 0v GL-Error is 24v and all vled-vcc are 24v led-on is 3.3v. cn6152 standby is 3.3v, ac det off is 3.3v, power on is 3.25v, audio 12v is 12v, t-con vcc 12v is 12v, and t-con on is 3.25v. on the led driver board all 4 vcc led test points are 34v. If I unplug cn4002 from led driver the tv will stay on and never shut off. When I disconnect the lvds cable from the balance board I get a nice white background with no dead led's in the picture, it gets a little darker and I can see a bright led bottom center. It is really pronounced when the screen turns red then shuts off. I did send the balance board in for testing and it was fine. The service manual says change the G board next which I believe is the power supply but I don't think that is it and now I am wondering if maybe the led driver or t-con might be failing. I did freeze spray the led driver board and it made no difference. Bottom line is does anyone have and suggestions? And now as I am writing this the 12v on cn 6753 reads 0v and that is most likely the problem.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Hi I googled jl2565 and found this CN2561 at PIN 3. It is for different model but may help.
              • nwcs
                • Dec 2015
                • 311
                • usa
                Thanks, I had also found that ant the voltage is at 3.3v so that leads to g board or tcon. at this point I am going to either order a power supply or the repair kit. Since I do not have the 12v I should be getting the 2 blink code with that missing. I am beginning to not trust the sony blink codes.
                • hernan_perez_br
                  • Jan 2011
                  • 37
                  Hi @nwcs, did you find the fix for your issue? Was it the power Supplu? I have the same issue but with 4 blink red lights. My tv is 46HX800 very similar to yours.
                  • Pukehead
                    • Nov 2018
                    • 25
                    The Sony KDL Service Manual is totally useless. I just ordered the repair kit from shop jimmy. Hope it fixes my KDL-55HX800. 2 blink code.
                    • Pukehead
                      • Nov 2018
                      • 25
                      So I replaced all the components in the repair kit and now the TV is worse. I cant even get the relay to switch.
                      • cloo
                        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                        by cloo
                        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                        After doing a factory reset this problem was gone and the picture was back to...
                        01-06-2025, 06:02 AM
                      • rmacintosh
                        Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                        by rmacintosh
                        I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                        The symptoms of the tv ar as follows:
                        • Plug AC in to back of TV
                        • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                        • The 3 blink code is given by the power LED
                        • If the TV is unplugged and then
                        03-14-2020, 12:24 AM
                        LCD LED TV Service Menu Codes
                        ALL LCD LED TV SERVICE MENU CODES
                        Service Menu Code with Board Name
                        China Universal Board / Jumper Board Service Menu Code
                        Changhong Ruba Service Menu Code
                        Ecostar LED TV Service Menu Code
                        Orient LED TV Service Menu Code
                        Haier LED TV Service Menu Code
                        TCL LED TV Service Menu Code
                        Samsung LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        Videocon LED TV Service Menu Code
                        Supra LED TV Service Menu Code
                        Toshiba LED TV Service Menu Code
                        Symphony LED TV Service Menu Code
                        Veste/ LED TV Service Menu Code...
                        10-31-2024, 03:58 AM
                      • reporter1979
                        2 red blink code on old led tv Sony KDL-40W2000
                        by reporter1979
                        Hi all, the TV KDL-40W2000 was flashed by a lightning.
                        Firstly I got the 3 red blink code.
                        Following other threads I changed the power supply board and got always 3 blinks.
                        So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                        The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                        What else can I do?...
                        02-17-2023, 11:50 AM
                      • Curtissimo
                        HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                        by Curtissimo
                        Hi everyone.
                        I have a HP Elitebook 850 G8.
                        Serial: 5CG2324XM0
                        ProdID 6L8D5EC#ABA
                        It has a Winbond W25Q256JVEN Chip.
                        I need to remove BIOS Password.
                        I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                        Attached my dump.
                        I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                        I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                        What I did:...
                        08-26-2025, 04:42 AM
