Panasonic Plasma TX-P42G15E 5 blinks
  • meciu
    • Nov 2016
    • 37
    I'm owner of a Panasonic VIERA TX-P42G15E with 5 blinking led issue.
    I've searched of any guide how to deal with this problem so at this moment I know that:
    - One transformator makes a humming noise after powering on TV, but afer 1-2 sec power supply turns off and LED starts to blink
    - Pin 1 on connector P35 isn't shorted
    - Pin 5 of connector P25 isn't shorted
    - There is around 5V on pin 5 of connector P25 (my multimeter lags so the highest voltage I can see before PSU turns off is about 4,5v)
    - Tried to swap PSU board but still 5 blinks.
    Now I'm almost sure that A board is broken, but I cannot find that one with matching number from the sticker, only boards from G15B are availible (my board is TXN/A1DYUE and availible on ebay are TXN/A1DYUB)
    Is there any way to fix this? I'm missing my good plasma
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic Plasma TX-P42G15E 5 blinks
    Nah--5V line issue will cause sos 5, monitored by pin 60 of micro....
    Lots of stuff can cause that, the P board the SC and the SS could cause this fault.
    --Disconnect the three ribbons from A board as well as the SC2 and P2, as well as the similar cable to the SS.
    Test again check if it gives sos code or runs. Prolly runs, then check-
    Q401, Q402, Q441, Q442, Q661, D865 et on SC
    TELEFIX
    • tw2005
      • Oct 2011
      • 6458
      I'd check the SC board too, I have put up a chinese tech bulletin for SOS5 due to SC baord failure, try searching the sc board number maybe in the forum
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Biruslapio
        Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
        by Biruslapio
        Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
        It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
        It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
        02-16-2021, 09:44 PM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
