I have a Samsung lcd tv model LN37A550P3F that has a flashing power light on front of tv, I have taken off the back of the tv and looked at the power supply, I see no bulged or leaking caps, I try to turn it on and there is no clicking sound from power supply board but the blue glow light on the bottom front of the tv comes on and that's it, the power supply board is BN44-00216A
Samsung lcd Tv flashing power light
Re: Samsung lcd Tv flashing power light
Have a read of this thread
https://www.badcaps.net/forum/showth...ht=BN44-00216A -
C102 on the Main Bd is highly likely the culprit causing your problem.Comment
https://www.facebook.com/Telford-Tel...7894576335359/Comment
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
by lapfixHP OMEN : DAG35DMBAD0
NO power ,no short ,no corrusion
Consumption : when charger plg in = 0.004 amp
Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
No light at power button led
All coils resistances :
Pl 2001 =3v measured with kohm.
pl 2004 = 5v measured with kohm
pl 6001 = 49.7ohm
pl 4012 = vccsa = 24.4 ohm
pl 3001 =... -
by CraigRWorking on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
by stephonwhyteun65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
Thanks for all responses. - Loading...
