LG 42sl8000 inverter noise?
  • nackgr
    • Mar 2015
    • 18
    • greece
    Hello
    I have this tv LG 42sl8000
    and both inverter boards do a buzzy noise ( the right it is louder)
    The board is 6632L-0574A
    http://www.ebay.com/itm/LG-INVERTE-B...gAAOxyJX1TCsfP
    The noise comes from the 2 inductors (yellow big with thermal pad on them ) (i am not sure how to call them)
    What should i do ?
    Should i replace them ?
    Any idea how to search them they say on them l2-cf42-b-09902A-K0
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 42sl8000 inverter noise?
    I don't think there is a lot you can do other than ensure the solder joints are all good.
    The noise is probably due to the frequency of the driving signal in the coils vibrating the coils on the former on which they are wound.
    Someone else may have a solution.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Only time Ive had Inverters squeek/whine is when a tube or two are duff.
      The LG type are wired in parallel and the reduced load--due to duff lamps upsets the drive from the inverters.
      Get set on a full-white screen from some source or other, computer maybe--look for darker bars in image...
      TELEFIX
      • tony359
        by tony359
        11-28-2023, 05:18 AM
      • MegaZAC
        Onkyo TX-SR805 noise in one channel
        by MegaZAC
        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
        There's some logic behind it. As soon as I select an input I get only left...
        04-23-2025, 10:09 PM
      • courtcircuit
        Philips HTS8000 home cinema noise problem
        by courtcircuit
        Hello
        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
        Removed each of tyhe boards
        02-08-2025, 08:22 AM
      • x_orange90_x
        Vizio E55-E1 bad backlights or bad inverter?
        by x_orange90_x
        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
        I don't know how exactly to test the inverter itself. Is it...
        01-29-2025, 09:24 PM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
