Philips 42PF9431D/37 LED blinks 5x(red)
  • tlerohl
    • Nov 2016
    • 12
    This blinking LED would happen off and on for a few yrs. I would unplug the power cord and plug it back in and it would work again for anywhere from a month to 6 months. This last time it wouldn't come back on. I have attached Pics. You will notice a missing CAP in image 4329. I took (2) Samxon 680uf 100v caps out because of a post I read but don't know which brand to replace them with. I tested a cap I bought at Radio shack (for testing purposes only) and got a reading within .11 uf of the rating but when I tested these 2 caps I get something that says 0.F (which I guess means they are bad). Any help would be much needed and appreciated.
  • tlerohl
    • Nov 2016
    • 12
    Re: Philips 42PF9431D/37 LED blinks 5x(red)
    Sorry, I thought I added the pictures but here they are.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Could you please heat up the board with a hairdryer? Do it for a few minutes and see if the tv will come on again. If so , you probably have bad capacitors on the powersupply.
      • tlerohl
        • Nov 2016
        • 12
        Should I reinstall the 2 caps I removed? This would be the only way to know if this works.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yes install the caps lol, if they are failed replace them with new low esr ones like Panasonic fr series.
          • tlerohl
            • Nov 2016
            • 12
            OK, So lets first start with the LED flashed 7 times not 5. I think I read too many forums about 5 blinks before taking things apart and posting.
            With that said, once I re-installed the 2 caps initially I got the 7 blinking red lights. Then we put a hair dryer to the board and the tv powered up.
            Please tell me what my next step should be. Your help is appreciated!
            • tlerohl
              • Nov 2016
              • 12
              Bump
              • vinceroger69
                • Mar 2012
                • 6714
                if the tv powered up when heated you need to narrow down the area your heating to find the bad parts but my guess its a bad capacitor with high esr (heat tempory brings it down hence tv works) maybe fully re cap the power supply.
                • tlerohl
                  • Nov 2016
                  • 12
                  How would I know what Caps to buy for a full recap? I am open to it. (I waited before posting until I had a meter that could read higher capacitance. (Mine only went to 40 farad which is why I couldnt get a reading on the 2 caps I pulled). Bought a nice Fluke. I am ready to try this and appreciate any help provided.
                  • tlerohl
                    • Nov 2016
                    • 12
                    bump
                    • tlerohl
                      • Nov 2016
                      • 12
                      bump
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Need voltage lists. Vs, va, 15v etc.
                        • tlerohl
                          • Nov 2016
                          • 12
                          Of each Cap? I will have to remove each one or at least one of each size to figure that out. There isnt a list based on model of TV or board? I would hate to not get them all back in the right place a week or two later (once I have the replacement caps).
                          Does this pic help at all?
                          • tlerohl
                            • Nov 2016
                            • 12
                            bump
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              basically how i recap a board is remove each capacitor one at a time write down the circuit board location number then take a note of the voltage and uf of the capacitor then you can measure its height/width (some times this does not matter if you have the room on the pcb for larger replacements)
                              so do this for all the capacitors on your board i usually leave the largest one on the primary side thats usually ok then get a list of the others and order replacements i usually use panasonic fc/fm/fr series if you had a capacitor/esr meter you could of measured each one and only replaced any thats out of spec.
                              • tlerohl
                                • Nov 2016
                                • 12
                                I do. I bought a Fluke 177 so I could read capacitance. Don't I need to remove each one from theboard to get a proper reading?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  that only measures capacitance i think you need to measure esr as heat is making the set work
                                  this is one of the best budget esr meters at the minute and can measure a lot of other components too,
                                  http://www.ebay.com/itm/182321753067
                                  and yes best to remove the capacitor and test you maybe able too narrow down which capacitor is bad as heat is making the psu work maybe get a cardboard tube and aim the air down that so you can narrow down the area which makes the psu work then narrow down the area too the bad capacitor takes time but can be done this way but how i see it all the capacitors are probably the same age so if ones failed the others may be not far of failing
                                  do not heat the capacitors too much as they can explode with too much heat.
                                  • cliff_hootarski
                                    • Jul 2006
                                    • 411
                                    Short answer to your question is, YES you do have to remove the caps to test for proper capacitance and ESR.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4955
                                      • New Zealand
                                      A capacitance meter is not as useful here as an ESR meter, because it's usually the ESR of the capacitor which changes (increases), rather than the capacitance changing.
                                      The (likely) reason your TV works when you heated it with the hairdryer is that the capacitors which have failed are returning to a semi-usable state (their ESR drops) when you heat them. Sometimes capacitors fail with reduced capacitance, but in that case heating them does not usually do anything.
                                      You need to check them all with an ESR meter to find the bad ones, though you should test their capacitance too, just to be thorough. Occasionally a capacitor may fail with reduced capacitance while its ESR reads fine on the meter.
                                      Yes you should do component tests out-of-circuit for the most accurate readings.
                                      -David VanHorn
                                      • Biruslapio
                                        Panasonic P58V11B 8 and 12 blinks error "fix"
                                        by Biruslapio
                                        Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                        Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                        04-13-2021, 07:13 AM
                                      • jimbofz
                                        philips 55 oled 745 /12 3 blinks
                                        by jimbofz
                                        Hi this tv was fine until the owner moved to another address,
                                        it comes on in sby with 3 blinks and psu wont start up .
                                        tried a power on reset by holding down power on button on rear of tv and applying mains no luck
                                        first inspected for damage dry joints or loose foils no joy
                                        checked psu volts ,the 12v and 24v supplies should be switched on by the main board no volts
                                        i read on the net that the micro on some later philips may need a reflow ,removed psu checked all caps with esr meter all ok
                                        removed main board
                                        and heatsink on micro
                                        heated...
                                        02-15-2021, 05:49 AM
                                      • G33RT
                                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                        by G33RT
                                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                        It does power up when pressing the power button.
                                        I already try the power button while plugin the plug with no result.
                                        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                        Could this be an PSU or eMMC issue ?
                                        07-19-2025, 03:43 AM
                                      • Andre Gilbert
                                        by Andre Gilbert
                                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                        11-20-2024, 08:52 PM
                                      • Taurus12
                                        Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                        by Taurus12
                                        Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                        I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                        i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                        Any recommendation on what I have to do next? Thanks in advance
                                        06-10-2025, 05:05 PM
