60PN5700 stopped working
+ More Options
Posts
  • Gator_bud
    • Nov 2016
    • 7
    New poster.....hope you guys can help.
    After watching football all day, the screen went blank while watching a show. It then started turning off and on by itself, with no picture or sound (internal sound was turned off as I have a sound bar).
    Since then, I have tried to research the issue and came accross this fantastic site. Based on all things I have read, I have tried the following:
    - All boards connected - once turned on, snowy screen for 1 sec, turns off by itself, 2 sec later turns back on to "lighted" blank screen. No sound. Stays on until I turn it off.
    - Disconect Ysus from Zsus - same thing as above, but no snowy screen and blank screen is not "lighted". (my Ysus is connected to the Zsus, then Zsus to power supply)
    - Disconnect Z from power - same thing as Ysus disconnected.
    I then came accross this posting for the same TV, with same issues: https://www.badcaps.net/forum/showth...light=60pn5700
    So I tried the EXT AUTOGEN trick and a saw a clean/clear test pattern (Bright white screen, turned off/on, then cycled through all the colors and white/black going up/down/side to side......then repeated pattern.
    Does this mean that the Ysus and Zsus are fine? That the main board is the culprit? IF so, what is my next step? I can't find a replacement board anywhere. Is there a way to troubleshoot my board and fix it myself?
    Thanks,
    Dave
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: 60PN5700 stopped working
    What you are describing is certainly a main board fault. Probably not much more you can do for troubleshooting on it yourself as you've already narrowed it down to that board. You can look for a replacement on eBay or I'd highly recommend contacting PTS electronics about repairing yours for you. I use them frequently when a board repair is over my head. They are quite speedy and reliable.
    • Gator_bud
      • Nov 2016
      • 7
      Thanks Aaron......I reached out to them and am awaiting a response.
      • Gator_bud
        • Nov 2016
        • 7
        Heard back from PTS Electronics and they agree that it is most likely the main board....however, they said they can't fix my board. Anyone have any other ideas? I don't want to buy another TV.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          If they cant fix it, then a replacement board is the only option. Fault-finding on an MB is a nightmare--Even for experienced engineer...
          TELEFIX
          • Gator_bud
            • Nov 2016
            • 7
            Thanks Alastair.....
            After more research, it looks like LG has a substitute part # that can be ordered from them. I am going to try it out......will report back.
            Dave
            • Nick's Tvs
              • Jan 2014
              • 621
              Gator bud,
              If you are unable to find a good replacement main board, send me a message I can probably fix that board for you.
              • Gator_bud
                • Nov 2016
                • 7
                Thanks for all the help......I picked up the substitute replacement main board on Friday and it worked.
                I appreciate all th feedback from all on this thread and the diagnostic advice on other threads within this forum......
                Dave
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  Thanks for the update have you got the number of the substitute board you found worked as it may help other members in the future with repairs.
                  • Gator_bud
                    • Nov 2016
                    • 7
                    my old board was EBT62495013
                    The new substitute board is EBT62495011
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • ipatch
                      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                      by ipatch
                      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                      08-24-2024, 02:36 PM
