Samsung LA26R71BA cannot power up
  • john_doe
    • Apr 2013
    • 192
    • Malaysia
    #41
    Re: Samsung LA26R71BA cannot power up
    Hi dick_barton,
    With PS_ON connected to standby 5.2 vdc, the voltage at the big cap is 63 vdc.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #42
      In post #34 the voltage was 323V? so with PS_On connected to 5.2V did this voltage rise??
      • john_doe
        • Apr 2013
        • 192
        • Malaysia
        #43
        It dropped to 63 vdc. It is still connected to the dim bulb tester.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          #44
          I generally don't use the bulb so perhaps Vincerogers69 can answer.
          If it's falling to 63V then I assume it's at 323V prior to connecting PS_ON.
          Connecting PS_ON then drops the voltage to 63V so the PFC circuit must be switching on because current is flowing through the lamp and dropping most of the voltage across the lamp which then becomes brighter.
          I would with caution remove the lamp, replace the fuse and try again and hope everything is OK. The voltage at the capacitor should rise when PS_ON is connected.
          You may wish to wait to hear from Vincerogers69 before trying.
          • vinceroger69
            • Mar 2012
            • 6714
            #45
            i would try it now with out the bulb tester as you have your five volts standby etc i usually find if theres a short circuit the bulb lights full brightness straight away.
            with no short the bulb should just barley glow if thats the case i usually remove the bulb replace the fuse and power on.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #46
              Thanks for the confirmation Vincerogers69.
              • vinceroger69
                • Mar 2012
                • 6714
                #47
                Im still learning myself but using a dim bulb tester does seem to save parts if you have missed a faulty item maybe budm will confirm the bulb wattage we should be using and what to expect as in bulb brightness etc under diffrent circumstances.
                • john_doe
                  • Apr 2013
                  • 192
                  • Malaysia
                  #48
                  I disconnected the bulb tester but with 1k resistor still connected from PS_ON to standby 5.2 vdc.
                  As soon as i power up, i blew up NT811S.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #49
                    Now that I did not expect!!! The NT811S is the inrush current limiter.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #50
                      Can you check QP801S, QM801 & QM802 with the set off using your meter on ohms to see if any of them are short circuit.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #51
                        What new parts have you fitted to this psu already?
                        • john_doe
                          • Apr 2013
                          • 192
                          • Malaysia
                          #52
                          With multimeter set to ohm, the resistance across CP802 is 30k ohm.
                          For QM801 and 802, pin 1 to 2, the resistance is 3M ohm. Pin 1 to 3 is 11 ohm and pin 2 to 3 is 3M ohm.
                          Ì replaced FP801A, ICP801S and QP801S. Total 3 new parts.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #53
                            Sorry, my mistake, the first components should have been QP801S
                            QM801, QM802 look fine.
                            Can you show a close up photo of ICP801S
                            • john_doe
                              • Apr 2013
                              • 192
                              • Malaysia
                              #54
                              For QP801S,
                              Positive Negative
                              Pin 1 to 2= 290k ohm
                              Pin 1 to 3= 99k ohm
                              Pin2 to 3 = 400k ohm
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #55
                                Isn't QP801S the mosfet that you originally replace.
                                • john_doe
                                  • Apr 2013
                                  • 192
                                  • Malaysia
                                  #56
                                  Pic of ICP801S
                                  • john_doe
                                    • Apr 2013
                                    • 192
                                    • Malaysia
                                    #57
                                    Yes, i replaced QP801S.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #58
                                      Originally posted by john_doe
                                      For QP801S,
                                      Positive Negative
                                      Pin 1 to 3= 99k ohm
                                      Something does not make any sense.
                                      If the mosfet did not go short circuit then what caused the NT811S and fuse to blow!!!
                                      Could you check with your meter the resistance between Pin 1-2, 2-3, 3-4,4-5 etc for ICP801S and what is that shown on pin 4?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        for future refrence ive just saw this post tom66 wrote about using a dim bulb tester
                                        The lamp glowing indicates current is being drawn.
                                        Once the lamp goes out, very little current is being drawn.
                                        If there was a short, the lamp would be on continiously. So it should be OK.
                                        Most power supplies will do one of several things:
                                        - The lamp may flash or flicker
                                        - The lamp may glow once then go out once the main capacitor has charged up.
                                        - The lamp may glow dimly and the TV may operate (usually smaller TVs will run with a 100W bulb, larger ones may not work or may require a much larger bulb, 150-200W or so)
                                        Now there is one exception, if the TV has a relay on the power board which may turn off, there could be a short beyond this relay. If there is a relay, you want to find some way to keep it on continuously.
                                        so it depends how bright the bulb was glowing maybe something else was still short? its hard when we cant see things ourselves as in how bright the bulb is etc
                                        • john_doe
                                          • Apr 2013
                                          • 192
                                          • Malaysia
                                          #60
                                          Resistance
                                          Pin1 to 2 = 8.3M ohm
                                          Pin2 to 3 = 5.6M ohm
                                          Pin3 to 4 = 12.25k ohm
                                          Pin4 to 5 = 22.4k ohm
                                          Pin5 to 6 = 22.1k ohm
                                          Pin6 to 7 = 99.5k ohm
                                          Pin7 to 8 = 106k ohm
                                          The thing on pin4 is solder.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • mrtek
                                            Samsung UN43NU6950FXZA No power
                                            by mrtek
                                            Hi
                                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                            Main fuse = OK
                                            Back light LED = OK. Power them with aux power source
                                            LED output = OK 156V
                                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                            07-20-2025, 08:06 PM
                                          • hill01
                                            Samsung UE75MU7009TXZG Endless Power Cycle
                                            by hill01
                                            Hi everyone and thanks in advance for any help I might get here
                                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                            Since a few days, the TV won't turn...
                                            11-17-2021, 02:52 PM
