Building a cheap ACF tape bonding machine
  • Diah
    • Feb 2013
    • 6602
    Re: Building a cheap ACF tape bonding machine
    any bonding diy one with out Vacuum are useless to use ACF
    • capwizard
      • Jun 2016
      • 1991
      You mean use vacuum suck the screen to the work base, that is A wonderful idea, I know, because the Earth is spinning..and ..... earthquake...... .
      • capwizard
        • Jun 2016
        • 1991
        Where I can buy this X-Y micro adjustable table (I dont know the name! pic1)?
        I took those pictures two months ago. I need xy table to finish this project...
        PS: is 3D printer precision enough to do this job, I know nothing about machinarium.
        • b25mar
          • Dec 2016
          Now that ACF tape is available to buy and doesn't cost an arm and a leg (it's still pricey, but 50m of tape for $80-something sounds fair to me, considering the size of a tab), i have decided to build my own bonding machine.
          The few builds i have seen use a commercial bonding head and that costs $3000 to $5000 - OUCH. I was thinking more like $50.
          I have read the datasheet for the Hitachi ACF tape and it occurs to me that the requirements are not very stringent - the tape should reach 160 to 180C for 20 to 30 seconds, at a certain pressure applied by the bonding head. A suggested temperature (305C) for the bonding head is also given in the datasheet, and the only requirement for the head's shape is that it must have an even surface where it presses down on the tab (duh). There are no slopes required as it is with soldering BGAs, temperature just needs to get up there as fast as possible, stick there for 30 seconds then cool down. So the design of the control circuit is also easier.
          I have already chosen my heating element (it's a surprise, you'll laugh) and completed the design of the control circuit - all that's left is making the PCB. There is no microcontroller and no firmware involved, it's all analog. The output drives a relay so any kind of heating element can be used, and the input is a normal type K thermocouple. Control is accomplished via a couple pots and switches. The circuit turns the heater completely off once the time set has elapsed, and can also run a fan if desired.
          Anyone else interested?
          so what did you use for the heated head? I am trying to put together a bonding machine, hungry for info.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Nothing for now, no time/space/life stuff got in the way. Don't know whether i will have any more time to work on this project anytime soon, but will update if i do.
            A working TV? How boring!
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              You would think the Chinese would be selling a cheap bonding machine for like $500 by now
              • ajal14
                • Jul 2014
                • 7
                • canada
                #27
                Hi there, i am interesting in your project a home made ACF bonding machine. Did you made it, if yes can you help to make one for me?
                • patmeeg44@gmail.com
                  • Jul 2018
                  • 3
                  • United Kingdom
                  #28
                  Just got a job fixing tvs again & coming across loads of bonding problems, cant afford to buy one of those fancy bonding machines but would love to make my own
                    • Jul 2018
                    • 3
                    • United Kingdom
                    #29
                    just wondered could you help me build one
                      • Jul 2018
                      • 3
                      • United Kingdom
                      #30
                      Very interested in your project, I have just got a new job fixing TV's again after many years, I have not got the money to buy one of these fancy bonding machines. I would appreciate your help in making my own. (I hope this is not too much to ask) Just to add, I am based in Manchester UK.
                      Regards
                      Patrick
                      • angelos
                        • Dec 2012
                        • 573
                        • South Africa
                        #31
                        Just for your information. Here in South Africa there was a guy that imported one of these bonding machines from China. Upon arrival at customs the unit was sent back to China. The reason being that Samsung Electronics have arranged an agreement with the government to block these machines so as to protect the jobs of the locals that are assembling TV's here in South Africa. Nice hey.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          #32
                          Regards
                          Patrick
                          Sadly, this never took off due to the lack of time, maybe, just maybe, i'll get back into it this year.
                          Sad to hear about that deal in South Africa. Big manufacturers are determined to screw us over.
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                            Building a Laser / Spindle Engraving Machine very challenging
                            by sam_sam_sam
                            I have been trying to build this engraving machine for last few months it has very challenging to get the part together
                            I had bought a very small engraving machine a few years and it sat in the box it came in because I could not find a reasonable priced laser controller and the same thing about the the motor controller ( plus the table was to small for what I want to do with it )
                            I have some challenges about the machine controller as well because I want an offline function so I can run the project with out having a computer hooked to machine controller
                            09-27-2020, 04:43 PM
                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 03:28 PM
                          • CG2
                            Janome DC3050 Sewing Machine Pedal Resistance
                            by CG2
                            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                            04-14-2023, 07:53 AM
                          • triplefour
                            LG 75UN8570AUD panel issue fixed with tape.
                            by triplefour
                            I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                            add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                            07-17-2023, 10:22 PM
