Panasonic TX-L47E5B Image Problem?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    This set has me completely puzzled.
    The set appears to have the standard solarized image problem.
    A replacement TCON board arrived today and after installing it to my surprise I had exactly the same solarized picture.
    Lifting the panels right hand side tab from the tcon, I have a clear bright white picture on the right half of the screen with the left half grey.
    Replacing the tab and lifting the panel left hand tab from the tcon, I have a bright white picture on the left half and lines down the screen on the right side.
    There's also a wide vertical bar (light in colour) which can be seen in the photo's where an image is displayed that appears to fade in and out on the left side of the screen.
    The menu on On Screen images all display perfectly.
    Any idea's welcome
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Panasonic TX-L47E5B Image Problem?
    maybe a faulty lvds cable? its odd the menu is fine could it be a mainboard bga fault? have you done a factory re set and tried lvds settings in the service menu
    ive just read a post where tom says this
    Changing the LVDS format will mess up the colours. BUT, if it messes up the whole picture, it is the main board at fault. If it only messes up the background image, it is a T-con fault.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Hello Vincerogers,
      I've done a factory reset and also downloaded and installed the latest firmware. There's a possibility that I have purchase a faulty Tcon but I'm doubting this because the fault is identical with both boards.
      The mainboard BGA fault is a possibility because I see the feint line ( 2" to 3" wide) down the screen when there is a picture but is not there when there is no image to display.
      Thanks for the information.
      • vinceroger69
        • Mar 2012
        • 6714
        maybe worth trying a bit of heat on the mainboard chips see if that helps i doubt its another faulty tcon too but i guess if its a common fault you cant rule it out. Do panasonics suffer tab bond issues? these are just my thoughts reece/budm etc may have more ideas what may cause this fault.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          maybe a faulty lvds cable? Its odd the menu is fine could it be a mainboard bga fault? Have you done a factory re set and tried lvds settings in the service menu
          changing the lvds format will mess up the colours. But, if it messes up the whole picture, it is the main board at fault. If it only messes up the background image, it is a t-con fault.
          +1 bga solder IMO
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Thanks once again for your replies.
            What's the most reliable home method to redo the BGA chip. I have a hot air station and a thermocouple meter so that I can monitor the chip temperature. An idea of temperature(s) and time(s) would be welcomed.
            • diif
              • Feb 2014
              • 6978
              • England
              I had a Samsung Smart TV last week with dodgy BGA (no picture until i pressed on it).
              I stuck the board on my rework machine, I used the bottom heaters to warm the board then my hot air station to reflow from the top after putting some quality flux on all four sides.
              I used my backup thermocouple and got the top to about 230C and held it for a few seconds.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Thanks for your help there diif. Appreciated.
                • sordids999
                  • May 2013
                  • 2152
                  Try reflowing your BGA nothing to lose i have just fixed a 60 inch Sharp the same way it sounds wrong compared to a rework station but i use a dremel torch and some TOPNIK tk83 Flux always works for me
                  so far done a 47 inch LG led bad BGA (lines all over the screen and tv switching off) still working on my wall 9 months later and a few more tvs for friends all still working
                  good luck
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Again if I can ask what temperature and time you normally run at.
                    There are components on the top side of the BGA module so these may prove to be a nuisance, however I can cover them with Kapton tape to stop them flying off.
                    I've found a supplier on ebay selling a replacement board which is not too expensive so if it fails I can order it.
                    Edit
                    The problem may well be the BGA chip because it's linked to a heatsink using a thermal pad and the heatsink is held in place using plastic clips. The pressure applied to the chip is abysmal and the heatsink virtually floats freely above it.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      It did look like it was a BGA problem. After heating up the BGA chip the picture would flick between OK and solarized.
                      Decided to have another go and successfully killed it.
                      Replacement board on order.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Ok thanks for update, now we know bga is a common issue. I advise you put in some prevention methods-ie bigger heatsink with better thermal compound or thermal pad under the board or even a fan but probably over kill.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          +1 Yes it definitely needs a better heatsinking solution. As I said the current method is close to useless.
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            I have finally resurrected the TV again. Both the main board and tcon have been replaced however there is absolutely no difference in the display.
                            This is now leading me to conclude that the panel must be at fault.
                            The picture still displays a solarized look but generally only on the lower half of the screen and this is accompanied by flickering brightness, again only in the lower half of the screen. The backlights when viewed from the rear are steady and do not appear to be flickering.
                            When entering the service mode Self Check routine everything seems to be OK but it does give an SOS 1, but I do not know what that is referring to.
                            Interested in anyone's thoughts before I split the set up for spares.
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Just one last observation. When the screen is displaying the auto tune menu and occupies the full screen space, the picture is perfect. No solarization or flickering.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                All done and the set is now up and running as it should.
                                Due to my reluctance to strip down to the panel when looking at it previously, I reckoned that now I had nothing else to lose so decided to take a look at the tabs. So off came the side strips to gain access and what do I find; only what appears to be some tacky brownish gunge similar to Marmite, across one of the tabs.
                                Cleaned it all off and run up the set for a perfect picture.
                                I could kick myself for not looking earlier especially since there was always a top to bottom strip on the screen about 4" wide in line with that tab that was showing up whenever the picture content was dark.
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  I've seen a lot of these E5 models lately but i thought it was panel problem so i left them as is....
                                  Just saw this Panasonic E5 tv. You reckon its the same fault ?
                                  EDIT: Wrong picture , picture coming soon :p
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    Decided not to sell it and now use it as my main set. Really happy with it
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      You reckon this is the same?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        It certainly looks extremely similar except in your picture it looks a lot more noticeable than say in the 1st picture, Post#1.
                                        The other thing that was very noticeable was that the picture would also look solarized dependant on image displayed. See picture 3 where the thick line goes through her hair.
                                        • howardc64
                                          TCL 49S405 double image
                                          by howardc64
                                          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                          06-23-2025, 03:20 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • JSBJSB
                                          Panasonic OLED TX-65GZ950E no image
                                          by JSBJSB
                                          so I have this problem with this OLED that had a LED blinking issue at first.
                                          It was blinking twice so it means according to similar service manuals (I cannot find the proper one) EVDD 24V SOS, Panel or TCON Fault.
                                          Also, the connector from PSU to TCON which supplies 24V was burned (changed it) and saw threads about this topic but didn't relate completely to mine.
                                          First thing was to tape the signal ERRORDETECTION so it would try to initialize. And it didn't so I unplugged the panel from TCON.
                                          Then it started up and went to green light...
                                          05-14-2025, 02:39 PM
                                        • shlomim412
                                          samsung ua55es6800 - no image
                                          by shlomim412
                                          hi
                                          having problem with samsung ua55es6800
                                          tv had backlight on, sound working - responds to the remote control but no image.
                                          check tcon board - had 12v in but no other voltages present.
                                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                          when leaving only left side connected - again no voltages and no image.
                                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                          kept trying to block less pins on the left ribbon cable...
                                          05-15-2024, 05:00 AM
