Hisense LCD42V68PAM weird picture no BL
  • paulstef
    • Dec 2013
    • 724
    Hi guys,
    Front LED turns from red to blue, then blinks 6x red then stays blue, mainboard doesn't turn on the backlight and TV becomes unresponsive after power on. When I force the backlight on I see only a few square inch large noisy picture without any content.
    All voltages on the board are present, 12V, 3V3, 5V, 2.6V, 1V. Crystal for uC oscillates at correct frequency 27MHz but forcing it to stop doesn't do anything. It looks like the uC FW doesn't run...
    schematic is attached
    Any ideas?
  • CapLeaker
    Leaking Member
    • 8153
    Re: Hisense LCD42V68PAM weird picture no BL
    Probably the main IC, flash or the ram. did you check all the regulators and ldo's? Maybe try some heat or freezer spray (can of air upside down).
    • paulstef
      • Dec 2013
      • 724
      yes voltages are all there, heat has no effect, cooling spray is out.
      too bad...
      • petersor
        Hisense 58R6E3 Backlight/No Picture Repaired
        by petersor
        Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
        06-07-2024, 04:16 PM
      • Ierwin
        Philips 58PUS7805 Menu working but no/weird picture from video sources
        by Ierwin
        I got a 58pus7805 that shows some weird behavior.
        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
        I managed to install the latest official firmware by holding the control button while plugging...
        03-10-2024, 12:50 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • TVGuy419
        Hisense 75R6E3 No Picture
        by TVGuy419
        I replaced the backlights on this Hisense TV and the LEDs were showing on certain images. Drove me nuts, so pulled it apart, got new LEDs and put it back together. Now I don't have a picture. TV came apart very easily both times and I was very carful with the panel. I've replaced all the boards for good measure and still have the same issue. Unhooking either side of TCON board still gives me a blank screen with backlights and sound. Is it really possible the panel is junk just from taking it off with suction cups and gently placing it back in place?
        11-09-2023, 06:38 AM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
