sharp LC-32SH130K / Vestel 17PW82-2 v.1 090511
    So a friend has this TV which won't turn on and wondered if I could help as I managed to fix my Toshiba/vestel by replacing a resistor.
    Anyway, her TV doesn't turn on, the LED doesn't light up but the controls on the edge of the screen (TV/AV, channel, volume etc) do beep when pressed.
    I've had a quick scan of the forum but can't find much on this vestel board as to where I should start looking. None of the caps appear domed from what I can see.
    https://goo.gl/photos/EqmLJ4b66TU1REWx9
    There's plenty of replacement power boards on Ebay from £15 - £25 (which I know is the expensive way to fix it) but is it likely to be the power board?
    Andy
    Re: sharp LC-32SH130K / Vestel 17PW82-2 v.1 090511
    Hello Andy
    Is it possible that you attach your photo's to your message by using Manage Attachments.
    With any help given the photo's will still be on this site for others to see in the future and not become unavailable if and when you remove or delete them from google.
      Could you list the names of the pins and give the voltage on each one when
      a) In standby
      b) Out of standby
      eg
      Pin number, label, voltage
      In standby
      Pin 1 (Power_ON) 0.0V
      Pin2 (5V) 0.0V
      Pin3....
      etc
      Out of standby
      Pin1 (Power_On) 3.2V
      Pin2 (5V) 5.0V
      Pin3
      etc
        heres a schematic for the psu test the voltages as advised above first then we can advise more
          Hi - have updated the original post so images are included now.
          I'm new to all this but do have a multimeter. Are the Pins clearly labelled on the board?
          I also can't change it in and out of standby. When turned on there's no indication the TV is on other than beeps from the controls on the edge of the screen (TV/AV, channel, volume etc).
          The standby light does not illuminate.
            Once you are able to tell us what voltages you have on the connector pins people will be in a better position to advise you.
            Sometimes the connector pin names are on the underside of the board or printed on the top side of the pcb in a table form close to the connector if not given alongside the pins.
            Thanks to Vinverogers69 here are the connections for which the voltage readings would be helpful.
              OK, I'll see what I can do.
              Thanks for the help.
                if the pins are not marked use the schematic ive enclosed as it shows you what each pin should be voltage wise it and what does etc
                im not sure what multi meter you have but have put it on dc volts setting use the metal tv chassis as a ground (you do not need to measure the primary side ac volts for now) just test the secondary side voltages if your stuck on testing anything just ask and we can advise
                  Thanks. I'll be back in a few days then as the TV is still at hers. I'll pop around and test it when I get chance.
                    So, just so I'm 100%, we require the readings from all three componants PL802, PL804 and PL816?
                      looking at your pictures its the two connectors on the right with the wires going too them the one on the bottom row is double pins so a lot of diffrent voltages etc too take.
                      i dont think pl804 is used on your set once we get those voltages we can advise more if its a psu issue or mainboard but these psu s are troublesome this is whats in a repair kit for them.
                      POWER BOARD NUMBER:
                      • 17PW82-2 V.1
                      FAULT:
                      • DEAD - IC802 Q803 FAULTY
                      Whats in the kit?
                      • F800
                      • Q803
                      • IC802
                      • R829
                      • R823
                      • R817
                      • R818
                      • R819
                      • C840
                      • C801
                      • C814
                      • C892
                        Remove the Psu, flip it over and connect to mains. Test voltage across the filter cap what do you have ?
                          As dooosuk is a new member when doing this test be careful as it mains ac voltage! so set your meter to 600v if it has that setting with the set turned on what voltage do you get across the filter cap (the largest capacitor on the primary side of the psu)
                            Originally posted by vinceroger69 View Post
                            As dooosuk is a new member when doing this test be carfull as it mains ac voltage! so set your meter to 600v if it has that setting with the set turned on what voltage do you get across the filter cap (the largest capacitor on the primary side of the psu)
                            Thanks Vince...yes, I saw that 450v capacitor so knew to be careful when poking around.
                            Yes, my multimeter does have 600v AC setting so I'll give that a test whilst getting the voltages from the pins as well.
                              Yeah best to be careful it can hurt badly, if you have no or low voltage my guess is two diodes just before the filter cap have failed but if you have 360-390v on the cap something on the secondary is failed like I had in my video:
                              https://m.youtube.com/watch?v=N6Eo0BwRRJk
                                The voltage across the capacitors will be a DC voltage.
                                  OK, so just to double check everything:
                                  With the mains power on:
                                  1) Confirm voltage reading across main filter cap
                                  (done via multimeter on DC 600v setting and a probe on each solder point of the cap)
                                  2) Confirm voltage readings at pins of the connectors
                                  (done via multimeter on DC setting with one probe grounded to chassis and the other on the pin)
                                    Ive had he backlight-board give these symptoms....
                                    If PSU out of standby is giving 24V to backlight-board, but no light, try changing b/l board.
                                    TELEFIX
                                      Yes thats correct.
                                        OK, so I'm still alive.
                                        The filter cap read 399v when plugged into the mains. I was surprised here that I needed the mains cable plugged in and the black power cable from the logic (?) board plugged in and switched on, but that's just my lack of understanding I guess.
                                        The voltages below were all read when plugged into the mains and with the rocker power switch on the back of the TV 'on'. The TV will not switch in and out of standby so these are the only readings I could get.
                                        PL802 - do the two readings for pins 11 and 12 look ok?
                                        PL816 - Pin 13, 20 and 26 don't look quiet right according to schematic?
                                        Thanks for all the pointers so far. Your help is appreciated.
